Home Built Z 'Full video build'
Home Built by Jeff
My son chides me for not using a sanding block at times (uneven pressure when you're using your hand - it's not flat...).  I like to start by hand - I can feel debris that will scratch more than the 1500 or 2000 grit under the paper that way.  When I feel debris I immediately wash it away from the paint and paper. Once I've gone over by hand I start using a block for flatness (then I usually give it another quick once over by hand...  OCD).  I cringe a little when I see machine cutting.  Every time I've tried that I end up with deeper scratches than I want and I believe it's because debris gets caught in the grit - but you'll have no way of knowing it until you're buffing.
35 minutes ago, wheee! said:
I like the GM 10si or 12si alternator upgrade. Cheap and easy to find with 100-120 amps. Internally regulated and lots of power. Minor mounting mod.
Don't you still need the voltage regulator replacement adapter to go this route?
