Home Built Z 'Full video build'
Home Built by Jeff
The coil is new, so I didn't directly check it, but I did directly wire it to the battery. I will give it a better check tomorrow, but I am coming around to thinking the igniter is the issue.
20 minutes ago, tzagi1 said:
1:10 Rookie mistake #1
Never ever drain the oil before  removing the fill plug.
Absolutely. I have actually mentioned you should always do that in a previous video and totally forgot to do it this time.
The module needs a good ground also.  Power and ground.  Plus the ZX distributors are known for breaking the magnetic ring under the stator.  And they have bad bushings which let the sis pointed wheel contact the spikes on the outer ring.  Lots of small things to check with a ZX distributor.
lol, I saw that too... and shuddered a little waiting for the "face of doom" look as the fill plug couldn't break free. Lucky for you Jeff! I had to take a torch to my tranny to get the fill plug out!
  • Who's Online   0 Members, 0 Anonymous, 462 Guests (See full list)
