May 17, 20195 yr comment_575637 2 hours ago, Home Built by Jeff said: It is all in the video ? I watched the video?' i'm not sure if you said that was at the wheels or not? Link to comment https://www.classiczcars.com/forums/topic/58542-home-built-z-full-video-build/?&page=56#findComment-575637 Share on other sites More sharing options...
May 17, 20195 yr comment_575638 I noticed the Dyno RPM on the screen seems off? Was the dyno working OK? Link to comment https://www.classiczcars.com/forums/topic/58542-home-built-z-full-video-build/?&page=56#findComment-575638 Share on other sites More sharing options...
May 17, 20195 yr Author comment_575639 1 hour ago, Jason240z said: I watched the video?' i'm not sure if you said that was at the wheels or not? The engine was in the car, not on a stand so that should give you a hint ? Link to comment https://www.classiczcars.com/forums/topic/58542-home-built-z-full-video-build/?&page=56#findComment-575639 Share on other sites More sharing options...
May 17, 20195 yr Author comment_575640 6 minutes ago, 240260280 said: I noticed the Dyno RPM on the screen seems off? Was the dyno working OK? Are you talking about the road speed reading? The Dyno was all working well. Link to comment https://www.classiczcars.com/forums/topic/58542-home-built-z-full-video-build/?&page=56#findComment-575640 Share on other sites More sharing options...
May 17, 20195 yr comment_575650 The dyno stuff starts at about 10 minutes. 175 MPH! Link to comment https://www.classiczcars.com/forums/topic/58542-home-built-z-full-video-build/?&page=56#findComment-575650 Share on other sites More sharing options...
May 17, 20195 yr comment_575657 1 hour ago, Zed Head said: The dyno stuff starts at about 10 minutes. 175 MPH! MPH or KMH? Link to comment https://www.classiczcars.com/forums/topic/58542-home-built-z-full-video-build/?&page=56#findComment-575657 Share on other sites More sharing options...
May 17, 20195 yr comment_575658 Since this was done in Australia, it is probably KPH, which is about 109 MPH. Link to comment https://www.classiczcars.com/forums/topic/58542-home-built-z-full-video-build/?&page=56#findComment-575658 Share on other sites More sharing options...
May 17, 20195 yr comment_575660 It was fuzzy. I'm just glad there were no Newton-meter/seconds, or watts. Link to comment https://www.classiczcars.com/forums/topic/58542-home-built-z-full-video-build/?&page=56#findComment-575660 Share on other sites More sharing options...
May 17, 20195 yr comment_575665 I couldn't read any of the dyno read outs Link to comment https://www.classiczcars.com/forums/topic/58542-home-built-z-full-video-build/?&page=56#findComment-575665 Share on other sites More sharing options...
May 17, 20195 yr Author comment_575666 175kph. That dyno is strange though working in HP and ft/lbs as most here in Aus use KW and NM. Link to comment https://www.classiczcars.com/forums/topic/58542-home-built-z-full-video-build/?&page=56#findComment-575666 Share on other sites More sharing options...
May 17, 20195 yr comment_575667 11 minutes ago, Home Built by Jeff said: 175kph. That dyno is strange though working in HP and ft/lbs as most here in Aus use KW and NM. I was surprised to see it show HP. Every other dyno run I have seen in Australia showed power in KW. Link to comment https://www.classiczcars.com/forums/topic/58542-home-built-z-full-video-build/?&page=56#findComment-575667 Share on other sites More sharing options...
May 18, 20195 yr comment_575691 OK. I thought the Dyno screens was rpm but it was kph so that clarifies it. Link to comment https://www.classiczcars.com/forums/topic/58542-home-built-z-full-video-build/?&page=56#findComment-575691 Share on other sites More sharing options...
