December 5, 20186 yr comment_563082 1 hour ago, siteunseen said: Reminds me of the Black Knight from Holy Grail, "merely a flesh wound". That's what I tried to find but settled on Conan Link to comment https://www.classiczcars.com/forums/topic/58542-home-built-z-full-video-build/?&page=29#findComment-563082 Share on other sites More sharing options...
December 5, 20186 yr comment_563091 Link to comment https://www.classiczcars.com/forums/topic/58542-home-built-z-full-video-build/?&page=29#findComment-563091 Share on other sites More sharing options...
December 7, 20186 yr Author comment_563217 Time to install the clutch and gear box, getting ready to reinstall the engine to the car Link to comment https://www.classiczcars.com/forums/topic/58542-home-built-z-full-video-build/?&page=29#findComment-563217 Share on other sites More sharing options...
December 7, 20186 yr comment_563221 Dang! That transmission slid on easily for first time. Good work! Link to comment https://www.classiczcars.com/forums/topic/58542-home-built-z-full-video-build/?&page=29#findComment-563221 Share on other sites More sharing options...
December 7, 20186 yr comment_563243 Enjoying the video series. Great reference source as I go through my own rebuild with my son. Keep it up mate...are the roos still in the paddock out the back? Link to comment https://www.classiczcars.com/forums/topic/58542-home-built-z-full-video-build/?&page=29#findComment-563243 Share on other sites More sharing options...
December 7, 20186 yr comment_563246 Like the commenters on your YouTube channel said, the first dizzy is probably a points dizzy. Look under the cap for a set of points. The second is an electronic dizzy with the matchbox on the side. They came in 4 and 6 cylinder models. So look under the cap and make sure there are 6 trigger points and the interior is intact. They make a much better ignition in my opinion. Hotter spark and no points to mess with, but the matchboxes can fail. It is always good insurance to source another one and throw it in the glove box if it leaves you stranded. Link to comment https://www.classiczcars.com/forums/topic/58542-home-built-z-full-video-build/?&page=29#findComment-563246 Share on other sites More sharing options...
December 7, 20186 yr comment_563250 0:34, In your right hand you have an early 70's points dizzy, if you have your hart set on using it there are electronic conversion kits, occasionally you can find them on ebay for $30+- In your left hand you got a 79 up electronic version, these are really good!, 2 wire hookup, one to the (+) of the coil, the other to the (-). The biggest challenge is to phase it correctly, if you are to install the late dizzy into a early mounting tower you will find that there is no way to set up your timing properly, there are 2 solutions: 1. find a 79 and up mount (can be from a 4 cyl as well). 2. use a dremel to elongate the slots on the mounting plate. As always, before installation apply vacuum to the advance pot, make sure it doesn't leak and check the shaft bushings for wear, grab the shaft and try to move it sideways, if there is any play you will get erratic timing. Link to comment https://www.classiczcars.com/forums/topic/58542-home-built-z-full-video-build/?&page=29#findComment-563250 Share on other sites More sharing options...
December 7, 20186 yr comment_563253 Whichever distributor you choose make sure to check the breaker plate bearings for rust and gunk. They're almost always stuck after sitting for years. If you try to use them they might break the bearing cage. The ZX distributors, the one in your left hand with the module on the side, tend to break the stator magnet also. And they have weak bushings. I've seen replacement bushings out there somewhere. You can run a separate ignition module, like an MSD, using the points distributor. Link to comment https://www.classiczcars.com/forums/topic/58542-home-built-z-full-video-build/?&page=29#findComment-563253 Share on other sites More sharing options...
December 11, 20186 yr Author comment_563532 This week I get some help to put the engine and box back into the car. Link to comment https://www.classiczcars.com/forums/topic/58542-home-built-z-full-video-build/?&page=29#findComment-563532 Share on other sites More sharing options...
December 11, 20186 yr comment_563545 Mechanical Stig! That's cool! Link to comment https://www.classiczcars.com/forums/topic/58542-home-built-z-full-video-build/?&page=29#findComment-563545 Share on other sites More sharing options...
December 11, 20186 yr comment_563558 You didnt have an incorrect clutch fork, The problem is that you have to use the matching pushrod that has a half ball at the end...those are impossible to find unless you have one. same can be said for the clutch/ bearing collar combo, if they all matched there wouldn't have been an issue. Link to comment https://www.classiczcars.com/forums/topic/58542-home-built-z-full-video-build/?&page=29#findComment-563558 Share on other sites More sharing options...
December 14, 20186 yr Author comment_563735 This week I tackle the driveline, and try to make this collection of random parts work together. Link to comment https://www.classiczcars.com/forums/topic/58542-home-built-z-full-video-build/?&page=29#findComment-563735 Share on other sites More sharing options...
