January 29, 20196 yr comment_566966 There is no reason to reinvent the wheel, the car came from the factory with mounts for a 3 point seat belt, mounting a set of universal belt is quite easy, you will need a few longer bolts and spacers to mount the reels, the bolt size BTW is 7/16 fine thread. if there is interest I can take pics of mine. Edited January 29, 20196 yr by tzagi1 Link to comment https://www.classiczcars.com/forums/topic/58542-home-built-z-full-video-build/?&page=41#findComment-566966 Share on other sites More sharing options...
January 29, 20196 yr comment_566967 3 minutes ago, Home Built by Jeff said: This one is Fibreglass, not Urethane so it should not flex a crazy amount. I am still going to use the factory C pillar mount for the redirect so the angles will be as per factory. It is because the inertia reels are designed to be mounted vertically otherwise they won't work properly. As long as you are using a redirect up on the C Pillar, you should be ok then. Good to hear. Link to comment https://www.classiczcars.com/forums/topic/58542-home-built-z-full-video-build/?&page=41#findComment-566967 Share on other sites More sharing options...
January 29, 20196 yr comment_566972 I went with these https://www.wescoperformance.com/3pt-roadster-seatbelt-bucket-help.html with the retractor mounted in the old top belt bolt hole and the retractor inertia lock works fine. Link to comment https://www.classiczcars.com/forums/topic/58542-home-built-z-full-video-build/?&page=41#findComment-566972 Share on other sites More sharing options...
January 29, 20196 yr Author comment_566980 46 minutes ago, w3wilkes said: I went with these https://www.wescoperformance.com/3pt-roadster-seatbelt-bucket-help.html with the retractor mounted in the old top belt bolt hole and the retractor inertia lock works fine. I did try it and it locked up sometimes, but it took more inertia than it should, so I am more comfortable mounting them vertically as intended. Link to comment https://www.classiczcars.com/forums/topic/58542-home-built-z-full-video-build/?&page=41#findComment-566980 Share on other sites More sharing options...
January 30, 20196 yr comment_567036 Are you not using the rubber metal trims on the rear window seal? Link to comment https://www.classiczcars.com/forums/topic/58542-home-built-z-full-video-build/?&page=41#findComment-567036 Share on other sites More sharing options...
January 31, 20196 yr Author comment_567056 2 hours ago, Patcon said: Are you not using the rubber metal trims on the rear window seal? No Link to comment https://www.classiczcars.com/forums/topic/58542-home-built-z-full-video-build/?&page=41#findComment-567056 Share on other sites More sharing options...
February 1, 20196 yr comment_567143 On 1/30/2019 at 8:49 PM, Home Built by Jeff said: No Did you look to see if there was a window seal available with out the trim strip slot? I expect the trim actually helps hold the window in the car too Link to comment https://www.classiczcars.com/forums/topic/58542-home-built-z-full-video-build/?&page=41#findComment-567143 Share on other sites More sharing options...
February 1, 20196 yr comment_567156 They are available we used one on a car in 2017. Also I believe they are referred to on EBay as California seal? 72 body and block, everything else 71, Tokico springs, Illumina, R180 CLSD, 83 close ratio, 3.90 gears, Ztherapy SUs, BRE 15X7 Libre wheels and BRE front spoiler. Link to comment https://www.classiczcars.com/forums/topic/58542-home-built-z-full-video-build/?&page=41#findComment-567156 Share on other sites More sharing options...
February 5, 20196 yr Author comment_567457 In this episode I tackle the rest of the diamond stitched trim in the interior of the Z. Link to comment https://www.classiczcars.com/forums/topic/58542-home-built-z-full-video-build/?&page=41#findComment-567457 Share on other sites More sharing options...
February 8, 20196 yr Author comment_567690 In this episode I swap around the brakes and have another go at bleeding them. Link to comment https://www.classiczcars.com/forums/topic/58542-home-built-z-full-video-build/?&page=41#findComment-567690 Share on other sites More sharing options...
February 8, 20196 yr comment_567694 Jeff, your routing of the crankcase PCV and the valve cover breather may be wrong. The PCV outlet on the block is out only, and the valve cover vent is bi-directional . The little oil catch can you set up is an “in and out” you have one of the lines on the “out” port which defeats the filter mechanism inside. You will also have no positive breathing through the filter in the can! When all pressure is going in, it will effectively block ALL BREATHING from the block. If you install a filter on the "out" port and then route the valve cover hose to the top of the can, the air can move freely to the valve cover and still get clean(er) air from the can. The block will then be able to breathe. Some people just add a small filter to the valve cover to allow air in and out as needed. Then just run the PCV from the block to the catch can "in" port, block the "out" if you're not going to the intake, and put a filter on the top of the can to allow air to move out of the block. This will result in unmetered air going to the top of the engine and defeat the "circulation" of the engine air, but some people do it with no negative effects. Then again, this will probably set off a storm of posts from other viewpoints... Edited February 8, 20196 yr by wheee! Link to comment https://www.classiczcars.com/forums/topic/58542-home-built-z-full-video-build/?&page=41#findComment-567694 Share on other sites More sharing options...
February 8, 20196 yr comment_567722 @Home Built by Jeff Did you say that about the house? Link to comment https://www.classiczcars.com/forums/topic/58542-home-built-z-full-video-build/?&page=41#findComment-567722 Share on other sites More sharing options...
