October 16, 20177 yr comment_532537 On 10/16/2017 at 8:05 PM, Captain Obvious said: Help meeeeee.... Please hellllp meeee!! I'm no neurologist but one or 10 of these should help. Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=9#findComment-532537 Share on other sites More sharing options...
October 16, 20177 yr comment_532538 On 10/16/2017 at 8:05 PM, Captain Obvious said: Is that a LED shop light you're using in that last pic? That's a really weird effect. Those multiple hard edged shadows give me a headache! Help meeeeee.... Please hellllp meeee!! LEDs or flashbacks? Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=9#findComment-532538 Share on other sites More sharing options...
October 16, 20177 yr comment_532556 Time to replace that stock exhaust manifold with headers. Pictures of your Air Conditioning compressor bring back memories. My dealer installed AC was a $600 option and it never worked worth a $^!#. Dealer tried different changes over first 18 months and none ever worked in the Florida heat. I drove to California in 1974 during gas crisis for 6-month assignment at Edwards Air Force Base in Mojave Desert ........ the AC was useless. I ripped out the entire system but kept the AC compressor and brought it back to Florida. It is resting n my attic for last 40+ years. In those days the AC Compressor had one use ........ a boat anchor. Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=9#findComment-532556 Share on other sites More sharing options...
October 17, 20177 yr Author comment_532566 On 10/16/2017 at 9:54 PM, kinfish said: Time to replace that stock exhaust manifold with headers. Pictures of your Air Conditioning compressor bring back memories. My dealer installed AC was a $600 option and it never worked worth a $^!#. Dealer tried different changes over first 18 months and none ever worked in the Florida heat. I drove to California in 1974 during gas crisis for 6-month assignment at Edwards Air Force Base in Mojave Desert ........ the AC was useless. I ripped out the entire system but kept the AC compressor and brought it back to Florida. It is resting n my attic for last 40+ years. In those days the AC Compressor had one use ........ a boat anchor. It is gigantic! I would like the option of AC, I might look into the zx ac bracket and pump and upgrade my system. If I can use most of the parts. Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=9#findComment-532566 Share on other sites More sharing options...
October 17, 20177 yr Author comment_532567 Got the new 5/8 line in the mail today and got all lines replaced, this is the last of my lines that were old and brittle. It was a pain, but glad I got to clean the area and check for rust and get new grommets installed. Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=9#findComment-532567 Share on other sites More sharing options...
October 17, 20177 yr comment_532589 That looks really good. What did you do for the 5/8s on top of the tank, the 180 degree bend? I lucked out and got all my stuff from O'Reilly's. Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=9#findComment-532589 Share on other sites More sharing options...
October 17, 20177 yr Author comment_532611 On 10/17/2017 at 10:09 AM, siteunseen said: That looks really good. What did you do for the 5/8s on top of the tank, the 180 degree bend? I lucked out and got all my stuff from O'Reilly's. Evap tank or gas tank? I assume you are talking about the gas tank, I will either use a stainless rod bent, or a spring, I haven't decided yet, tank should be done and back this week. Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=9#findComment-532611 Share on other sites More sharing options...
October 18, 20177 yr Author comment_532654 Filter holder is now powder coated. I love doing all the little things. Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=9#findComment-532654 Share on other sites More sharing options...
October 24, 20177 yr Author comment_533092 Got the drive lines back today from having u joints pressed in. They came out pretty good, paint/ powder had some nicks from their press, so I had to do some touch up paint. The tech didn't like the powder on the end of the flanges. He said the powder will eventually wear down and cause slop. Anyone heard of this? Or think he is correct? Edited October 24, 20177 yr by duffymahoney Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=9#findComment-533092 Share on other sites More sharing options...
October 24, 20177 yr comment_533130 When you say "powder on the end of the flanges"... If what you mean is that you have powder coating on the mating surfaces of the flanges where the driveshaft mates to the differential, or where the axles bolt at either end, then I agree with your tech. I think there should be a hard, predictable, metal to metal contact there, and I worry that powder coating on those surfaces can extrude and squish out from between the two faces. Especially once things get hot and the coating softens from the heat. If that happens, you will end up with loose connections and it will snowball from there and probably result in snapped bolts. Might just be me, but I'd razor scrape off any paint on the mating surfaces and just apply a very thin coat of oil instead. Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=9#findComment-533130 Share on other sites More sharing options...
October 24, 20177 yr Author comment_533131 On 10/24/2017 at 1:56 PM, Captain Obvious said: When you say "powder on the end of the flanges"... If what you mean is that you have powder coating on the mating surfaces of the flanges where the driveshaft mates to the differential, or where the axles bolt at either end, then I agree with your tech. I think there should be a hard, predictable, metal to metal contact there, and I worry that powder coating on those surfaces can extrude and squish out from between the two faces. Especially once things get hot and the coating softens from the heat. If that happens, you will end up with loose connections and it will snowball from there and probably result in snapped bolts. Might just be me, but I'd razor scrape off any paint on the mating surfaces and just apply a very thin coat of oil instead. Yeah he wants the mating surfaces to be metal on metal. Only thing that has me arguing is the fact that the rear end had paint on the surface from the factory. On each side of the rear end. Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=9#findComment-533131 Share on other sites More sharing options...
October 24, 20177 yr comment_533132 Yeah, I'd want metal to metal. I'm no coatings expert, but most powder coatings I've messed with are much thicker than a coat of traditional solvent based spray. I'm thinking that one thin coat of traditional paint isn't nearly as problematic as a thick powder coat. Also, I believe powder coating is actually a thermoplastic coating (polyester?) melted into place. Reheat it and it melts again. Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=9#findComment-533132 Share on other sites More sharing options...
