duffymahoney Posted October 24, 2017 Author Share #109 Posted October 24, 2017 Powder is thicker then paint. But that depends on how much is used, I had him go thin. Powder melts at around 500 degrees. I can see the half shafts getting that hot. All surfaces mate up nicely with the powder. I guess I could remove it. But I could just check all bolts after a break in period. Which was my plan already. Any other input? Don’t the bolts hold it in place? Link to comment Share on other sites More sharing options...
duffymahoney Posted October 24, 2017 Author Share #110 Posted October 24, 2017 Got my other project home, my garage is starting to feel tiny:) Link to comment Share on other sites More sharing options...
Obie 280Z Posted October 25, 2017 Share #111 Posted October 25, 2017 The powder any job-shop or coater would normally use for this type application would be thermoset therefore u are good to go in that respect, most likely a TGIC or a urethane, both polyester resin. Epoxy powders will give better chemical/ gas resistance but will chalk eventually. Most solvent born coating would be in the 1-3 mils. range (DFT) and powder could be 2-10 mils depending how heavy handed they were. 2-4 mils powder would give your great look and protection. Sometimes tight tolerances and powder can be a problem unless masking/ plugs are used. Sorry for the details, been in the coating business for a while. Sent from my iPhone using Classic Zcar Club mobile 1 Link to comment Share on other sites More sharing options...
duffymahoney Posted October 25, 2017 Author Share #112 Posted October 25, 2017 I just bolted it up, I will tighten as needed. Link to comment Share on other sites More sharing options...
duffymahoney Posted October 26, 2017 Author Share #113 Posted October 26, 2017 (edited) Got the gas tank back from getting redkote. Now it's time to install it. Edited October 26, 2017 by duffymahoney Link to comment Share on other sites More sharing options...
wheee! Posted October 26, 2017 Share #114 Posted October 26, 2017 Looks great! Did you get new tank straps from Skillard too? I ordered a set with my Techno Toy order for my 76 and they are fantastic quality. If you order some, make sure you specify the year of the car several times. They shipped me the wrong ones twice. Third time is the charm I hope! Here is the 70-74 size next to my original 75-76 strap set. Link to comment Share on other sites More sharing options...
duffymahoney Posted October 26, 2017 Author Share #115 Posted October 26, 2017 1 minute ago, wheee! said: Looks great! Did you get new tank straps from Skillard too? I ordered a set with my Techno Toy order for my 76 and they are fantastic quality. If you order some, make sure you specify the year of the car several times. They shipped me the wrong ones twice. Third time is the charm I hope! My straps were fine, I just had them powder coated and glued the insulators back on. Link to comment Share on other sites More sharing options...
wheee! Posted October 26, 2017 Share #116 Posted October 26, 2017 Mine were rotted through in places. You are lucky! Link to comment Share on other sites More sharing options...
siteunseen Posted October 26, 2017 Share #117 Posted October 26, 2017 I'm going to be a little nosey here but I've done two tanks with Red-Kote and muratic acid. If you don't mind saying, how much did it cost? You could send me a PM or just not respond and I completely understand. I have had a couple of offers to do this for a guy and one of his buddies. I know the cost of materials but no idea what to charge for labor. Thank you, Cliff. Link to comment Share on other sites More sharing options...
duffymahoney Posted October 26, 2017 Author Share #118 Posted October 26, 2017 6 minutes ago, siteunseen said: I'm going to be a little nosey here but I've done two tanks with Red-Kote and muratic acid. If you don't mind saying, how much did it cost? You could send me a PM or just not respond and I completely understand. I have had a couple of offers to do this for a guy and one of his buddies. I know the cost of materials but no idea what to charge for labor. Thank you, Cliff. Radiator shop hot tanked it, acid dipped it, then I powder coated it then we did redkote. Also installed another drain for the redkote. I paid 200 for the dipping and acid. The redkote was free since he spilled (around the sending unit) some and I bought the materials. I ended up giving him a gift card for the work. He wouldn't let me pay him, since my tank looks flawless other then that. 1 Link to comment Share on other sites More sharing options...
duffymahoney Posted October 26, 2017 Author Share #119 Posted October 26, 2017 10 minutes ago, wheee! said: Mine were rotted through in places. You are lucky! My 240z, is very rust free. I will hopefully never drive it in the rain again, and it will continue to be this nice. Link to comment Share on other sites More sharing options...
wheee! Posted October 26, 2017 Share #120 Posted October 26, 2017 Looking forward to pics of it installed! Link to comment Share on other sites More sharing options...
