April 20, 20187 yr Author comment_547758 Ordered the fujitsubo exhaust system and the White head performance stainless adapter to my stock manifold. Not to get it all nicely purge tig welded and get the stupid exhaust studs off.  Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=17#findComment-547758 Share on other sites More sharing options...
April 25, 20187 yr Author comment_548035 Well I broke my exhaust manifold trying to remove a stud. So I think it's time for a header. Might as well match my fujitsubo exhaust. Darn. I wasn't ready for this decision. But might as well zinc the rest of the engine bay.  Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=17#findComment-548035 Share on other sites More sharing options...
April 26, 20186 yr comment_548070 That exhaust looks really clean, is it the revision that came out recently? Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=17#findComment-548070 Share on other sites More sharing options...
April 26, 20186 yr Author comment_548077 4 hours ago, heyitsrama said: That exhaust looks really clean, is it the revision that came out recently? Sent from my iPhone using Classic Zcar Club mobile Yes it is. I should have it mostly hung this weekend.  Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=17#findComment-548077 Share on other sites More sharing options...
May 2, 20186 yr Author comment_548549 Working on hanging it. So far so good. Hopefully getting the header back from ceramic coating friday.  Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=17#findComment-548549 Share on other sites More sharing options...
May 8, 20186 yr Author comment_548932 Worked on the valve cover over the weekend and also took the rest of the engine bay off for zinc.  Got a new NOS ballast for my ignition and also upgraded to electronic pertronix coil and points. 1.5ohm coil so hopefully my tach works.  Valve cover is wrinkle powder coated black. I love how it turned out. Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=17#findComment-548932 Share on other sites More sharing options...
May 10, 20186 yr Author comment_549087 I got the newer type spray bar back from being sonic cleaned and got the valve cover installed. Wow I love the black and zinc look.  This is Prismatic powder coating PWS 4344 Splatter Black      Edited May 11, 20186 yr by duffymahoney Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=17#findComment-549087 Share on other sites More sharing options...
May 11, 20186 yr comment_549101 Nice. I'm not a fan of most painted valve covers, but I gotta admit... I like that one. Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=17#findComment-549101 Share on other sites More sharing options...
May 11, 20186 yr Author comment_549102 2 minutes ago, Captain Obvious said: Nice. I'm not a fan of most painted valve covers, but I gotta admit... I like that one. Thanks! I will retain my stock one raw. Then vapor blast one. Then red. See which I like the best. Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=17#findComment-549102 Share on other sites More sharing options...
May 11, 20186 yr comment_549104 Do we get to vote?  Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=17#findComment-549104 Share on other sites More sharing options...
May 11, 20186 yr comment_549138 Love the exhaust...what did it cost all in? Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=17#findComment-549138 Share on other sites More sharing options...
May 13, 20186 yr Author comment_549227 Well got a ton done and really drove it! I removed the dealer AC unit. I will be modifying a aluminum 280zx mount to use a sanden pump later on. My giant ac pump makes it impossible to get to so many things. It had to go.  New fujitsubo (just came out) exhaust is in. Sounds great. My motor is bone stock, so it doesn't sound super beefy, below 2-3k rpms it almost sounds like any other car. But get on it and it opens up. I will try to post a sound clip soon. I was able to use my extra series 1 heat shield, just a few bends and it fits great. The ztheraphy carbs were easy to install and tune. My old ones are all gummed up and I couldn't adjust mixture. My flow meter died, so I still would like to re-tune and mess with timing more. My biggest issue came when I went to start it. I didn't mark on my old dist cap which was #1. Installed wires on the cap in stock location and nothing happened, it wouldn't try, etc.... I had so many new things new so I started with the carbs. Checked fuel, checked, ignition wiring (petronixs 1.5ohm coil, nos ballast and electronic points). Still nothing. I then found TDC and low and behold my dizzy is 2 cylinders off speared into the oil pump. Moved wires (#1 is where 4 should be now) and it fired right up! So now at some point I need to pull the oil pump and fix.   First time really driving it. Some harder pulls, some turns etc.. Even stock motor it's a blast to drive. Sort of scary, lots of road noise, but it was awesome! Not a lot of gas fumes, smells, which i am happy about. Engine bay puts off a ton of heat even with the ceramic coating on the header.   Next is Sanden pump install, along with a new dryer, lines and evap. Also I am binding mass loaded vinyl to the bottom of my new carpets for some sound damping.   Oil pressure is reading low, I really hope it's the sending unit. Motor has good compression (I need to re test, I got a new gauge) and doesn't burn any oil I can see.          Edited May 13, 20186 yr by duffymahoney Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=17#findComment-549227 Share on other sites More sharing options...
