duffymahoney Posted May 18, 2019 Author Share #373 Posted May 18, 2019 Ka is in. But I cut down a driveshaft had it balanced and powdercoated. I just used some measurements from posts but they are super off from my z. I really want a 4 post lift. Working under a car on jack stands sucks 2 Link to comment Share on other sites More sharing options...
german240 Posted May 19, 2019 Share #374 Posted May 19, 2019 Where did you buy this awesome transmission crossmember? BTW I used a Series 1 driveshaft which is slightly shorter. It fit without shortening (tight fit, around 5mm travel left). Link to comment Share on other sites More sharing options...
Jaymanbikes Posted May 19, 2019 Share #375 Posted May 19, 2019 23 hours ago, duffymahoney said: Ka is in. But I cut down a driveshaft had it balanced and powdercoated. I just used some measurements from posts but they are super off from my z. I really want a 4 post lift. Working under a car on jack stands sucks I love my 4 post lift. Best thing I ever purchased for the garage. I’m lucky I have tall ceilings. Link to comment Share on other sites More sharing options...
duffymahoney Posted May 19, 2019 Author Share #376 Posted May 19, 2019 I have a series 1. Which I guess means that my diff is further forward then later years. That’s why the series 1 driveshaft is too long. I will cut down an extra series 1 driveshaft I have. Link to comment Share on other sites More sharing options...
rturbo 930 Posted May 19, 2019 Share #377 Posted May 19, 2019 Why not get a later mustache bar and move the diff back? Link to comment Share on other sites More sharing options...
duffymahoney Posted May 19, 2019 Author Share #378 Posted May 19, 2019 That’s an option. I kind of like the goofy series 1 stuff most people don’t know about. Like me, till yesterday Shortening the driveshaft is the easier route. My overall plan with my z is crate everything that I take off and make everything easy to go back to stock with. Like my stock trans could be back in a few hours at most. Stock diff would be the same. Link to comment Share on other sites More sharing options...
duffymahoney Posted June 1, 2019 Author Share #379 Posted June 1, 2019 Shorten drive shaft is in. I wish i would have gone 1/8-1/4” longer. Also got the exhaust back hung. 1 Link to comment Share on other sites More sharing options...
duffymahoney Posted June 1, 2019 Author Share #380 Posted June 1, 2019 My z is getting the BIG Brake Kit from zcargarage. I’m so happy with it. Here is my thread on it https://www.classiczcars.com/forums/topic/62261-zcargarage-big-brake-kit/?tab=comments#comment-576731 1 Link to comment Share on other sites More sharing options...
Woody928 Posted June 6, 2019 Share #381 Posted June 6, 2019 This build is just nuts, there's some seriously high end items being used here! What's the end goal for it? It should drive amazingly with everything that you've done to date.... Very jelaous of the brake upgrade, it is beyond my means. Link to comment Share on other sites More sharing options...
duffymahoney Posted June 6, 2019 Author Share #382 Posted June 6, 2019 (edited) I don’t know if it’s nuts, but thank you. The goal is continue to have fun building it. This will be my last project for the summer then it’s driving time! Everything I do can be un- bolted and put back to stock as well. I am crating all original parts. Also I like the idea of it appearing mostly stock outside of the stance and visible stuff like brakes. Next? Honestly I don’t know. Part of me wants to crate the stock motor and build a more fun one. Who knows. Edited June 6, 2019 by duffymahoney 1 Link to comment Share on other sites More sharing options...
duffymahoney Posted June 13, 2019 Author Share #383 Posted June 13, 2019 I got married last week, so progress slowed down. Hopefully driving it this weekend. The e-brake is in. Basically attached right up. I used a simple C clip to hold it in. It doesn’t need it. But I thought it would help. I need to adjust it currently it too many clicks up, the goal is 5-6 the e brake calipers lock the wheels down crazy tight. I have installed the master. I found a write up on here about bench bleeding. I tried this method. I really liked it. Zero air left in. I’m going dot4 race fluid from stoptech. My favorite drive is a 10 mile 2k vertical hill climb to my local ski resort. Brakes get hot on the way down. I hate brake fluid. Hate it. Somehow I got some in my eye. 1 Link to comment Share on other sites More sharing options...
Patcon Posted June 13, 2019 Share #384 Posted June 13, 2019 Congratulations! Link to comment Share on other sites More sharing options...
