August 16, 20195 yr Author comment_582051 Plug clears with ease Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=38#findComment-582051 Share on other sites More sharing options...
August 16, 20195 yr Author comment_582052 I love how the harness will tuck Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=38#findComment-582052 Share on other sites More sharing options...
August 16, 20195 yr comment_582053 Oh, now that is nice! Looking forward to seeing this complete! Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=38#findComment-582053 Share on other sites More sharing options...
August 20, 20195 yr Author comment_582269 I got all my boots in, I wish there was an easy way to test the coils. But I know the spring is compressed on the spark plug, so I should be good. How has everyone run new ecu wiring into the engine bay? My early 240z has dealer AC. Which complicates things. Really I only have two holes open. The choke cable hole and the tunnel hole near the shifter. I would rather not cut any holes. If I leave the coil power wiring in the engine bay and do the o2 sensor and maybe the triggers for the coils through tunnel hole I am thinking I might have enough room for it with those two holes? It’s going to be tight, but I think I can do it all clean and nice. I will be using german braied loom for the whole project. No pulsed outputs. Plans Choke hole Injector wiring Cas wiring Air temp Coolant temp TPS Crank trigger wiring Tunnel hole Injector triggers Power and ground O2 sensor Fuel pump wiring is already in place. I also got in the euro kit from Hoke for my crank trigger. Which should work better on my series 1 dampener. I have to remove .08 from the backside to have it perfect. Then off to paint. Blue or black?! Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=38#findComment-582269 Share on other sites More sharing options...
August 20, 20195 yr comment_582271 The 280Z has a lot more options for wiring as there is the original FI hole on the drivers side plus the standard wiring harness hole on the passenger side. Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=38#findComment-582271 Share on other sites More sharing options...
August 20, 20195 yr comment_582274 I used my AC holes since I don’t have AC. Where are you mounting the ECU? I split up my harness running my sensor wires out the opposite side of the engine using the choke hole. Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=38#findComment-582274 Share on other sites More sharing options...
August 20, 20195 yr comment_582275 15 minutes ago, madkaw said: I used my AC holes since I don’t have AC. Where are you mounting the ECU? I split up my harness running my sensor wires out the opposite side of the engine using the choke hole. I haven't decided yet. I have the original ECU location behind the panel on the drivers side footwell, but I also want easy access for the USB port for programming. I actually have a plan to run a USB extension into the dash for the Haltech programming. I also have the CANBUS kit that needs to be installed as well for the wideband O2 sensor. Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=38#findComment-582275 Share on other sites More sharing options...
August 20, 20195 yr Author comment_582277 I will do the canbus wideband as well. I will do the passenger kick panel install. Datsun spirit sales a plate that bolts in. Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=38#findComment-582277 Share on other sites More sharing options...
August 20, 20195 yr comment_582281 I mounted my MS3 on the trans tunnel on passenger side . Since I decided to run my harness thru the AC holes I figured I would keep the ECU closer to that . Not sure there is a right or wrong for location- it depends on the owners set up. Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=38#findComment-582281 Share on other sites More sharing options...
August 22, 20195 yr Author comment_582356 Working on my 280zxt Cas signal, so I can do full sequential. I got a very nice 280zxt distributor without a cas from a fellow Datsun nerd. I then found a basically new fully Nissan Cas from a 1998 Nissan Quest. Which has the correct trigger wheel. Pretty neat. Dizzy is getting vapor blasted today and I should have it all installed by the weekend. Pretty excited! Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=38#findComment-582356 Share on other sites More sharing options...
August 27, 20195 yr Author comment_582687 280zxt dizzy is done. I vapor blasted it the housing, wrinkle coated the godzilla race works cap and new zinc hardware. I might not be able to live with the size of it. It's pretty huge. Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=38#findComment-582687 Share on other sites More sharing options...
August 29, 20195 yr comment_582804 Have you seen the thread on Hybridz using the Jeep cam angle sensor ? Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=38#findComment-582804 Share on other sites More sharing options...
