Also got my Jeep cas back from the machine shop. It’s nice and tight on the keyed shaft. Should work perfectly. I used the original dizzy collar as well.
Efi Fuel system is in and wired. Happy with how it turned out. ITB here i come. All pushlock. I might switch some of it out to 5/16 from -6 braided. The braided seems a little large and out of place.spacer.pngspacer.png
Edited by duffymahoney
Duffy, I love these fuel lines, very clean and professional.  Am I right to assume that you are making them up as needed? What kind of tools do you need to make them?
Really enjoying this build, to my eye every modification is spot on.
Center fuel rail has hard lines between. They have an O-Ring. I haven’t decided on raw or not yet. Maybe powder coated or anodized!?
Thank you!
I bought a push lock fitting tool. Which is all you need. Then fittings from anhosefittings.com
Parts back from zinc and a new water pump.
Also finished the fuel pressure sensor.
Billet P clamps work perfectly with the stock fuel rails. Screws right on
Built a passenger kick plate out of aluminum. I will powder coat it to match my stock one (sort of darker matchbox )This ecu location is about the best location I can find.
