Duffy's 1/71 Series 1 240z build
duffymahoney
Well this bosch and all bosch IACs of this style let a ton of air by when closed.  Bosch said roughly 30-35%.  Which makes the butterflys useless at idle.  My next iac will be a ford.  Which closes all the way and only lets a tiny bit of air by.
Edited by duffymahoney
Mines a Volkswagen version. Probably gonna have the same issue...
Was yours a three wire? Mine has a pull down resistor to ground to keep it closed.
Edited by wheee!
12 hours ago, duffymahoney said:
 Now to find out what pin is positive.
If there are just two connections and it's a simple spring loaded solenoid valve inside, it really shouldn't matter which pin is which. It should operate the same regardless. But if there's anything else in there (like even a protection diode), polarization would matter.
PCV question. This isn’t a debate about the need for a PCV vs a catch can. I want true postive vent. I decided I want to use my exhaust to pull the fumes out, to keep the dirty fumes out of my intake. But since I have Fujitsubo. I have true dual exhaust. Is plumbing to one good enough? Should I still use the stock check valve? I would guess it holds back a tiny bit of pressure before popping open?
My plan was to weld this bung at a 45 just past my o2 bungs on my exhaust. With the stock check valve in line.
