On 5/13/2020 at 12:07 AM, duffymahoney said:
3.2L engine parts arrived from Rebello today!
JE Pistons, Eagle rods and king race bearings. Rod bearing clearances are spot on. Marine Crank did a fanstatic machining job on my extra long stroke LD crank.
Your pistons look just like mine with the dish . What CR are you shooting for and what CC chamber in the head ?
2 hours ago, Yarb said:
That included his machine work?
No. I think a fully built Rebello motors are 8-20k.
I didn’t get a Rebello kit. Just parts we needed.
10:1 is the goal. I will only use ethanol free premium.
15 hours ago, Patcon said:
So what is in the Rebello 3.2 kit?
What do you have to provide?
What head will you pair with it?
From Rebello
I got titanium valve retainers, pistons, rods, bearings etc...
I will be using a ported and bigger valve E31.
Machine work will all be done locally.
Crank repair and stroke was done by Marine Crankshaft.
5 minutes ago, Patcon said:
So not using the LD28 block?
That goes to 3.4L, doesn't it. I believe it requires a custom crank though
No. Just a N42 block bored. I’m not chasing a ton of hp. The 3.4+ is a lot of work and $.
I actually think I will be at at 3.16 or something. But that sounds dumb. So 3.2L
17 hours ago, 73str86 said:
Duffy you've done some great work to this S1 240z! I've been lurking for a while. Nice to see some chronological history of your build instead of just Facebook.
- Jeremy Wilbur
Thank you! Trying to make it a blast to drive, tinker, but also I can go back to bone stock fairly easily.
Well injectors are back and I have efi spark plugs.
I spent a while tuning this weekend and with Tioga’s help I think I finally found one of my major problems.  The tps was set at its highest sensitivity. It would bounce from .34-.49. Thus causing the ecu to think it needs to apply timing and fuel and making it run terrible. I turned it to the lowest and it’s rock solid at 0% and .01 of a voltage change.
Haltech is a nice system. But wow is there a lot of settings.
If anyone needs Z car help. I would recommend Tioga with Automotive Solutions!
  • 1 month later...
