Duffy's 1/71 Series 1 240z build
duffymahoney
14 hours ago, hiyabrad said:
Looking so sweet!
The block color was scanned and then matched, from pictures it looks a little light, but hopefully in person its perfect.  It's hard to judge block color, mine darkened with time/ age, but the parts with none of that the blue is pretty light.
Your's looks great! I'd give anything to go back to the 1st rattle can color I used, Ford blue. I ended up going to Pontiac blue and it's too pale. It has darkened some with time though so it's not as "baby boy blue".
I rebuilt this 82-83 turbo distributor today. New bearing, all new zinc and a new z31 cas.
only issue so far is the Cas disk I have might be bent.
also
Cas turbo upgrade method #2. This is for a 82-83 turbo distributor.
Instead of using long nuts and bolts. I thought this would be a cleaner install.
Drilled out the base to allow m5 jis screws. Then threaded and tapped the maxima cas
Hey duff
Love your build mate! Safari gold, black RKRs, red calipers! Your taste is impeccable!
Few questions for you as looking at doing a few things the same as you,
1. With the 15x8s RKRs did you get any rubbing with the bc coilovers or big brake kit?
2. How have you found silverlines stage 3 kit? Performance wise, done any light track work? Did the brakes hold up?
Ryan
  • Who's Online   1 Member, 1 Anonymous, 844 Guests (See full list)
