47 minutes ago, Patcon said:
Thailand?
How many are you making?
I will probably sell like 20-25 kits. A guy in thailand makes a bunch of stalks for the r35 coils.  He will be making these, same material as stock.
Edited by duffymahoney
  • 3 weeks later...
  • 1 month later...
No injector ports are shown.  Is that bar meant to be a fuel rail?  The nipples are confusing, with one in the middle and one on the end.  Why would you want the injectors so far from the head?
Is this just a thought experiment or are you really planning to build something?
This will use my EFI throttles, so injectors at the throttles, the angle of the intake puts the injector spraying right down the middle of the runner!  Bar on the bottom is for map signal, it uses 6mm banjos. Middle port will be for the ECU, end will be for the FPR.  I will be making at least one.
