Well I got my prototypes in for my passive cooling on my Efi hardware throttles! These will be between the heat shield and the throttle bodies. Also it will be a nice and clean way to run the return fuel.
I love it when a plan comes together.  This is custom titanium banjos, which will come off my balance bar and hold my heat shield on!
  • 1 month later...
On 1/16/2025 at 8:17 PM, conedodger said:
Duffy,
I wonder if there is a way to report oil temp and pressure to the ECU? Have you got a solution for that?
You can get a oil temp sensor, oil pressure is a must sensor for the ecu.
A little update on my 3.1L! This motor was actually finished 3 years ago, but was tragically in a shop fire. Luckily the engine wasn’t too close to the flames and it was spared. It’s getting close  to finished and then going into my 1971 240z!
My 3.1L
10.2:1 compression ratio
88.5mm bore. N42 block. Sonic tested.
LD crank by marine crankshaft. Crank Off-set grind to 84.6 stroke. Finish rod journals @ 1.8889"
Thrust Finish 1.27”R & R plugs with threaded plugs Dynamic Balance Ion-Plasma nitride, straighten & micro-Micro polish all journals
E31 head. Port work by Andrew Kazanis
Dsi valves, titanium retainers. Isky springs.
Bonk cam. I got it in NOS or near new condition prior to porting.
Rebello JE Eagle pistons and toyota rods
221 CFM flow at .45-.5 lift. With rougAndrew Kazanis sizes.
Mine is 88.5x88.5x.25x3.14159x 84.6x6 /1000 = 3122cc
Thank you Andrew Kazanis for all the help and your magically porting work.
240z hidden drive by wire actuator for my ITB setup. This is design number 4.
This plan utilizes a Efi hardware actuator. The goal is the same length arm to the bell crank and distances from shafts and the rod. So the rod passes through the firewall evenly and doesn’t walk from left to right.
This will mount to the pedal plate and the steering box mounts. So behind the firewall
Prior designs walked too much in the hole and I don’t want that.
  • 1 month later...
Well I decided to pick a new header. I wanted the header to give my room on port 5-6 for my lower mounted actuator and also get out of the way of the throttle bodies a little more. I decided on the Kameari drag 45mm. Which I purchased through Binh Nguyen.
The header design gives me plenty of clearance for my actuator and throttles! Pretty darn happy with it overall. Prior I had a now moth balled Fujitsubo header. Which had a terrible runner design for a lower actuator.
