August 12, 20195 yr Author comment_581772 The goal will be to add zero holes and make the whole project easily reversible. Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=35#findComment-581772 Share on other sites More sharing options...
August 12, 20195 yr comment_581775 Really cool project. Does the ports on your intake manifold match up with the intake ports on the head? Seems to me when I was at Eiji’s shop, the Jenveys needed work on my head to match the ports on the intake. Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=35#findComment-581775 Share on other sites More sharing options...
August 12, 20195 yr comment_581779 Cool! I think the L series engine will run a lot better with individual spark control, especially if you are going to run the Haltech Elite 750. Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=35#findComment-581779 Share on other sites More sharing options...
August 12, 20195 yr Author comment_581780 34 minutes ago, Diseazd said: Really cool project. Does the ports on your intake manifold match up with the intake ports on the head? Seems to me when I was at Eiji’s shop, the Jenveys needed work on my head to match the ports on the intake. Jenvy’s should match right up to my SK intake. Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=35#findComment-581780 Share on other sites More sharing options...
August 12, 20195 yr Author comment_581782 First test print to look at clearances. I think it will need to be angled more. Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=35#findComment-581782 Share on other sites More sharing options...
August 13, 20195 yr Author comment_581849 I just learned that my hoke 60-2 should be enough to get the ecu all the data it needs for the crank/ cam. Pretty neat! Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=35#findComment-581849 Share on other sites More sharing options...
August 13, 20195 yr comment_581850 How does the wheel support the cam sensor? Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=35#findComment-581850 Share on other sites More sharing options...
August 13, 20195 yr Author comment_581851 2 minutes ago, madkaw said: How does the wheel support the cam sensor? You lost me a little. What do you mean? Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=35#findComment-581851 Share on other sites More sharing options...
August 13, 20195 yr comment_581853 The wheel is for a crank sensor , Im not sure how it works for a cam sensor . Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=35#findComment-581853 Share on other sites More sharing options...
August 13, 20195 yr Author comment_581854 2 minutes ago, madkaw said: The wheel is for a crank sensor , Im not sure how it works for a cam sensor . I get a little confused on all the signals and such. But most crank sensors are 36-1 which tells the ecu it a lot of info but not enough to know if it's intake or exhaust. The 60-2 tells the ecu exactly what stroke its on. So that is all it needs. But again, I am a giant newbie on all of this. So? Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=35#findComment-581854 Share on other sites More sharing options...
August 13, 20195 yr comment_581856 You have a link to this product - I can’t find it . I thought 60-2 wheel is just another version of a 36-1 wheel. I thought two separate sensors were needed or two separate wheels to run sequential Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=35#findComment-581856 Share on other sites More sharing options...
August 13, 20195 yr Author comment_581858 https://hokeperformance.squarespace.com/l-series-crank-angle-sensor https://hokeperformance.squarespace.com/store/l-series-crank-angle-sensor-kit Haltech just said 60-2 is enough to run it all. I have an email in to them as well. Curious on it all Link to comment https://www.classiczcars.com/forums/topic/58568-duffys-171-series-1-240z-build/?&page=35#findComment-581858 Share on other sites More sharing options...
