June 11, 200321 yr Author comment_40517 I hope I answered your questions in the private messege.There is a pic of the tool taken apart on my page at zdriver. Link to comment https://www.classiczcars.com/forums/topic/5858-spindle-pin-tool/?&page=2#findComment-40517 Share on other sites More sharing options...
June 11, 200321 yr comment_40600 240z I was gonna ask the same question. However I removed these on my 240z with no problems. The problem was nobody could supply me with the lower A arm bushings to install and this was on my Roadworthy list.I ended up just replacing the rubber circular item that goes over the pin and between the nut and washer. He didn't even know that I didn't replace them and I sure as hell wasn't gonna do it given that a RW check must be done again in 7 days.I did attempt to remove these at a junk yard once and out of the 4 I didn't get more than 1 out. I guess I was just lucky I lubed them back up to install them again.Try using the nut over the end as ben mentioned and give a good whack with a heavy hammer try not to damage it however and u did remove the pin halfway at the bottom didn't u? Link to comment https://www.classiczcars.com/forums/topic/5858-spindle-pin-tool/?&page=2#findComment-40600 Share on other sites More sharing options...
June 12, 200321 yr comment_40644 I'll give it another go, but it will be a while. Leaving town this weekend & will be back late the week afterwards, so it might be 2-3 weeks before I give it another shot. I whaled on it pretty good before, so a rest break is probably a good thing. The lock pin is definitely out. Thanks for the advice. Link to comment https://www.classiczcars.com/forums/topic/5858-spindle-pin-tool/?&page=2#findComment-40644 Share on other sites More sharing options...
June 12, 200321 yr comment_40649 Before you leave, soak it as much as possible with a good penetrating oil. Who knows, it might loosen it up enough to remove it when you get back. Be sure to put as much as possible in the hole the lock pin came out of so that it soaks into the center of the pin.What would be really nice is if you could find a long shallow pan that it would fit into that you could let it soak in penetrating fluid while you are away....:devious: Link to comment https://www.classiczcars.com/forums/topic/5858-spindle-pin-tool/?&page=2#findComment-40649 Share on other sites More sharing options...
July 11, 200321 yr Author comment_43462 More spindle pin tools will be available shortly. Please let me know if interested.Thanks Marty for the referrals. Link to comment https://www.classiczcars.com/forums/topic/5858-spindle-pin-tool/?&page=2#findComment-43462 Share on other sites More sharing options...
