October 13, 20177 yr comment_532283 before drawing any conclusions you should get new correct plugs, drive for a week and pull them again. For all you know those plugs could have looked that way when installed (used plugs). It happens. If the car is not smoking, pulling strong, no misfires, chances are it need nothing but running. Edited October 13, 20177 yr by Dave WM Link to comment https://www.classiczcars.com/forums/topic/58722-failing-valve-guides/?&page=2#findComment-532283 Share on other sites More sharing options...
October 13, 20177 yr Author comment_532292 All responses acknowledged and will report back any updates. Thanks so much to all. Great forum. I see myself hanging out here more often. Cheers! Link to comment https://www.classiczcars.com/forums/topic/58722-failing-valve-guides/?&page=2#findComment-532292 Share on other sites More sharing options...
October 13, 20177 yr comment_532295 I should say that failing valve guides is not a bad guess, although seals would be more specific. They will leak more oil at idle under high intake system vacuum and dirty up the plugs pretty quickly. Then when you start driving much of that will burn off. My original engine had bad seals and would run rough after putting around town, then would clear up after I gave it one of those high rev tune-ups. It was fun for quite a while to have a reason to go beat on the engine, trying to figure out why it ran so much better afterward. After I removed the engine and took the head off, I noticed oil draining down the intake and exhaust valves after just a little while. The seals weren't sealing at all. There's quite a bit on the site about changing valve seals. Pretty easy, I think, and might make a big difference. In short - I second madkaw's thought, in Post #2. Link to comment https://www.classiczcars.com/forums/topic/58722-failing-valve-guides/?&page=2#findComment-532295 Share on other sites More sharing options...
October 13, 20177 yr Author comment_532297 6 minutes ago, Zed Head said: I should say that failing valve guides is not a bad guess, although seals would be more specific. They will leak more oil at idle under high intake system vacuum and dirty up the plugs pretty quickly. Then when you start driving much of that will burn off. My original engine had bad seals and would run rough after putting around town, then would clear up after I gave it one of those high rev tune-ups. It was fun for quite a while to have a reason to go beat on the engine, trying to figure out why it ran so much better afterward. After I removed the engine and took the head off, I noticed oil draining down the intake and exhaust valves after just a little while. The seals weren't sealing at all. There's quite a bit on the site about changing valve seals. Pretty easy, I think, and might make a big difference. In short - I second madkaw's thought, in Post #2. Thank you. That's the plan. Drive it with new plugs, recharged k&n filter and monitor. Link to comment https://www.classiczcars.com/forums/topic/58722-failing-valve-guides/?&page=2#findComment-532297 Share on other sites More sharing options...
October 14, 20177 yr comment_532319 I’m betting incorrect jetting. Read up on your carbs before you buy or turn any screws. You can do more damage than good. Read. Read. ReadSent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/58722-failing-valve-guides/?&page=2#findComment-532319 Share on other sites More sharing options...
October 14, 20177 yr comment_532320 On more. Does your car have a AFR Meter? If not that needs to be your first purchase in my opinionSent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/58722-failing-valve-guides/?&page=2#findComment-532320 Share on other sites More sharing options...
October 14, 20177 yr Author comment_532322 11 hours ago, Dave WM said: choke function working correct? (wont start without it, pulling it when warm makes engine stubble rich). No choke Link to comment https://www.classiczcars.com/forums/topic/58722-failing-valve-guides/?&page=2#findComment-532322 Share on other sites More sharing options...
October 14, 20177 yr Author comment_532323 22 minutes ago, Travel'n Man said: On more. Does your car have a AFR Meter? If not that needs to be your first purchase in my opinion Sent from my iPhone using Classic Zcar Club mobile This? Reads 5 consistently when given a little throttle. Link to comment https://www.classiczcars.com/forums/topic/58722-failing-valve-guides/?&page=2#findComment-532323 Share on other sites More sharing options...
October 14, 20177 yr comment_532326 That's a fuel pressure gauge. 5 psi might be a little high for Webers, but I don't know Webers. Float bowls and valves are all similar though and 5 seems a bit on the high side. AFR stands for Air Fuel Ratio (even though air actually contains fuel) and AFR meters are used to help make adjustments to hit a certain fuel air ratio. But the old school ways will work also. No offense Travel'n Man. People have tuned many carbs before AFR meters came about. They're great for fine tuning but he can make a lot of progress just by eye, and butt, from where he's starting. Link to comment https://www.classiczcars.com/forums/topic/58722-failing-valve-guides/?&page=2#findComment-532326 Share on other sites More sharing options...
October 14, 20177 yr comment_532327 I still do not have a AFR for my triples. Still on my list. I have gotten the plug reading to a nice light tan color with out it so far. Are you running an electric fuel pump? Stock mechanical pump? Both together? Do you have a FPR installed? 5 psi is a little too high. It could be actually even higher. I am not too keen on some of those gauges. Float levels definitely need to be verified as well before anything else. Link to comment https://www.classiczcars.com/forums/topic/58722-failing-valve-guides/?&page=2#findComment-532327 Share on other sites More sharing options...
October 14, 20177 yr Author comment_532346 I still do not have a AFR for my triples. Still on my list. I have gotten the plug reading to a nice light tan color with out it so far. Are you running an electric fuel pump? Stock mechanical pump? Both together? Do you have a FPR installed? 5 psi is a little too high. It could be actually even higher. I am not too keen on some of those gauges. Float levels definitely need to be verified as well before anything else.Both fuel pumps I was told. Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/58722-failing-valve-guides/?&page=2#findComment-532346 Share on other sites More sharing options...
October 15, 20177 yr comment_532382 I suggest you do some research on your carbs and get some basic understandingSent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/58722-failing-valve-guides/?&page=2#findComment-532382 Share on other sites More sharing options...
