Posted October 13, 20177 yr comment_532302 I need to replace the rear wheel cylinders in my 71 240Z. The cylinders changed in the 72 - 73 time frame. The early wheel cylinders go for almost $200 where the later goes for less than $50. Has anybody used the later model in the early car? Here's a picture of the later model on the left and the early model on the right. The only difference I can see is the part where the bleeder valve stick through the back plate is taller and the soft brake line connection is 90 degrees vs angledĀ in the early model. Link to comment https://www.classiczcars.com/forums/topic/58728-early-late-wheel-cylinders/ Share on other sites More sharing options...
October 13, 20177 yr comment_532311 I did it on my '72s rears. Ā I swapped the hardlinesĀ from one side to the other then bent them to fit into that 90 degree port. I will find the thread and post it up Saturday a.m I remember a lot of replies and a few good pictures. Here it is with some more threads linked from other members experiences. http://www.classiczcars.com/topic/50122-early-72-wheel-cylinder-problem/ Link to comment https://www.classiczcars.com/forums/topic/58728-early-late-wheel-cylinders/#findComment-532311 Share on other sites More sharing options...
October 14, 20177 yr Author comment_532328 Thanks so much for the reply! The drums are off after a little torch work. When attempting to bleed the left rear I broke off the bleeder stem so I figured I'd be replacing the wheel cylinders. When I saw the price of the 71 vs 73 wheel cylinders and then compared them visually I hoped there was a way to make the swap! The 4X price of the early cylinder is ridiculous. Link to comment https://www.classiczcars.com/forums/topic/58728-early-late-wheel-cylinders/#findComment-532328 Share on other sites More sharing options...
October 16, 20177 yr Author comment_532472 Got the early wheel cylinders changed over to the later version cylinders just fine. My buddy Dan changed a bend in the brake line and it still runs just fine around the front of the drum back plate. can't imagine paying ~$200 a piece for the early cylinders when the later version can be had for ~$40 a piece and work just fine! Link to comment https://www.classiczcars.com/forums/topic/58728-early-late-wheel-cylinders/#findComment-532472 Share on other sites More sharing options...
December 19, 20186 yr comment_564090 w3wilkes, Thanks for this thread!Ā I really didn't want to spend $450+ for left and right wheel cylinders, and this post gave me the courage to go with the later-model cylinders. I replaced the old "hard-lines" with new (20inch) which wasn't too expensive (about $6 each) or difficult to bend. For the record, my hard-lines don't do a tight 90deg turn. They come out of the cylinder and do a tight "U" turn then do a gentler 90 toward the front. Thanks again! Link to comment https://www.classiczcars.com/forums/topic/58728-early-late-wheel-cylinders/#findComment-564090 Share on other sites More sharing options...
December 19, 20186 yr Author comment_564099 Glad you found this thread and that it worked out for you... Now, what else to do with all that money you saved!? ? Link to comment https://www.classiczcars.com/forums/topic/58728-early-late-wheel-cylinders/#findComment-564099 Share on other sites More sharing options...
