Posted October 17, 20177 yr comment_532634 I have a bad starter and ordered a replacement from AutoZone. When it came in it appeared to be a little different than the ones I saw on the internet. Specifically, it had a cone nose and the bendix moves out on a shaft like most of the starters I've ever seen. The pictures I saw on the internet do not have the cone but are simply flat. I guess the bendix simply protrudes out and engages the ring gear when the starter is activated. I have not removed mine and AutoZone is holding the one I ordered until I find out if it will work. The starter at AutoZone has a pamphlet that says the starter may look different but is appropriate for the 280zx. In looking again on the internet I have found others that have the cone shape nose that are indicated for the 1980 280 zx. Anyone know for sure if a cone nosed starter will work? Link to comment https://www.classiczcars.com/forums/topic/58755-starter-question/ Share on other sites More sharing options...
October 17, 20177 yr comment_532636 It will work but the 280ZX starters have more torque, I believe. They are gear reduction starters. The cone nose is a 240Z to 280Z type starter. It's a regression. You can use 280ZX starters on Z's and vice-versa. Link to comment https://www.classiczcars.com/forums/topic/58755-starter-question/#findComment-532636 Share on other sites More sharing options...
October 18, 20177 yr Author comment_532662 Thanks. I got the one with the cone, installed it and it seems to be working fine. Still wish I had been able to get the reduction gear starter. The original lasted 37 years, so if this one lasts half that long I’ll probably be toes up. Link to comment https://www.classiczcars.com/forums/topic/58755-starter-question/#findComment-532662 Share on other sites More sharing options...
