Posted October 23, 20177 yr comment_533068 Any idea why a stock 280z 1978 has a back fire problem blowing out blue smoke Link to comment https://www.classiczcars.com/forums/topic/58793-1978-280z-back-fire/ Share on other sites More sharing options...
October 23, 20177 yr comment_533071 fuel mix not right vacuum leaks, unmetered air, ECU, Sensors, ign timing, smoke from burning oil from warn out engine, valve guides, seals, rings, pvc issues, wrong oil. one thing at a time, start with a compression check, then check ign timing, then fuel pressure test. Need a lot more info before a meaning remote diagnosis can begin. Link to comment https://www.classiczcars.com/forums/topic/58793-1978-280z-back-fire/#findComment-533071 Share on other sites More sharing options...
October 23, 20177 yr comment_533072 Ditto to all of the above. Some car and engine history would be helpful too.. Link to comment https://www.classiczcars.com/forums/topic/58793-1978-280z-back-fire/#findComment-533072 Share on other sites More sharing options...
October 24, 20177 yr comment_533097 Try unplugging the cold start valve? My 240 starts blowing blue when I leave the choke on too long. Link to comment https://www.classiczcars.com/forums/topic/58793-1978-280z-back-fire/#findComment-533097 Share on other sites More sharing options...
October 24, 20177 yr Author comment_533103 Thankyou, will replacing the ingine help get the car starting...won't start or stay on, when it does is back firing Sent from my SAMSUNG-SM-N910A using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/58793-1978-280z-back-fire/#findComment-533103 Share on other sites More sharing options...
October 24, 20177 yr comment_533104 Plug wires are placed in backward rotation order in the distributor. It will run, but poorly. Link to comment https://www.classiczcars.com/forums/topic/58793-1978-280z-back-fire/#findComment-533104 Share on other sites More sharing options...
October 24, 20177 yr comment_533106 1 hour ago, diego1988 said: Thankyou, will replacing the ingine help get the car starting...won't start or stay on, when it does is back firing Sent from my SAMSUNG-SM-N910A using Classic Zcar Club mobile I'm usually the one that confuses but you got me with this? Link to comment https://www.classiczcars.com/forums/topic/58793-1978-280z-back-fire/#findComment-533106 Share on other sites More sharing options...
October 24, 20177 yr Author comment_533108 I'm thinking off doing an ingine swap with transmission....guessing this will solve all my problems Sent from my SAMSUNG-SM-N910A using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/58793-1978-280z-back-fire/#findComment-533108 Share on other sites More sharing options...
October 24, 20177 yr comment_533110 23 minutes ago, diego1988 said: I'm thinking off doing an ingine swap with transmission....guessing this will solve all my problems Sent from my SAMSUNG-SM-N910A using Classic Zcar Club mobile Well, that would be one way........ But simply figuring out your current engine would be more economical. Just my 2 cents. Link to comment https://www.classiczcars.com/forums/topic/58793-1978-280z-back-fire/#findComment-533110 Share on other sites More sharing options...
October 24, 20177 yr Author comment_533112 Sent from my SAMSUNG-SM-N910A using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/58793-1978-280z-back-fire/#findComment-533112 Share on other sites More sharing options...
October 24, 20177 yr Author comment_533113 I feel like the ingine is dead oil going into the spark plugs and the distributor is Gone. I have almost no mechanic skill Sent from my SAMSUNG-SM-N910A using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/58793-1978-280z-back-fire/#findComment-533113 Share on other sites More sharing options...
October 24, 20177 yr comment_533115 Owning a Z will turn you into a mechanic. Very knowledgeable people here that have done it all and then some. You can start here http://www.classiczcars.com/files/ by downloading the Factory Service Manual for your 78. Learning how to repair your Z is invaluable and easier than an engine swap if you don't have the experience yet. Link to comment https://www.classiczcars.com/forums/topic/58793-1978-280z-back-fire/#findComment-533115 Share on other sites More sharing options...
