Z31 N/A RB project
five&dime
My body guy made a perfect fit patch panel to fill the side marker on the front fender he is doing a sprayout for. I pulled the engine harness, master cylinder and starting to pull the brake lines now. Going to paint soon.
Engine bay is stripped other than the front subframe with steering lines and the gas lines since I have the rubber hoses capped off. The subframe and steering will come out when it gets painted. The painter is going to build a rolling cart for it while he does all the body work and paint.
This was just a test spray out to make sure 100% that I wanted the color on the car. This is the MZR Roadsport spray out method. Concept Color here in Richmond went ahead and did the body work on it to shave the side marker and fit the later year body parts but he will sand and reshoot this fender with the final car soon so no need to buff. He did a mighty fine job on the simple spray out and I am very excited that he is painting this car.
Edited by five&dime
