Posted November 5, 20177 yr comment_534209 Hi everyone: I’m installing my seatbelts and the shoulder belt portion is fine. However the side with the release latch I can’t figure out how to attach this. I thought initially the bolt hole would be on the transmission tunnel but then I see this attachment point. If I try to attach it so that the receptacle is pointing forward (between the tunnel and the car seat) it’s impossible to get a secure connection. There is a curve in the body that doesn’t allow the seatbelt attachment point to lay flat. If I orient the belt so that the attachment point lines up perfect, then the belt is basically pointing towards the back of the car versus forward. I was also thinking do I have the wrong belts for my 260z? Howard Edited November 5, 20177 yr by 882993md Link to comment https://www.classiczcars.com/forums/topic/58895-seat-belt-release-attachment-point-correct-belts-for-260z/ Share on other sites More sharing options...
November 5, 20177 yr comment_534210 I sent a text to a friend with a stock 260Z to see if he can get a photo of the inner part of the belt mounted to the tunnel. Link to comment https://www.classiczcars.com/forums/topic/58895-seat-belt-release-attachment-point-correct-belts-for-260z/#findComment-534210 Share on other sites More sharing options...
November 5, 20177 yr Author comment_534212 Thank you !! Link to comment https://www.classiczcars.com/forums/topic/58895-seat-belt-release-attachment-point-correct-belts-for-260z/#findComment-534212 Share on other sites More sharing options...
November 8, 20177 yr Author comment_534404 I scoured the internet for 240z/260z seat belt location/attachment pictures and was able to find the following pictures. It seems my latch side doesn't have enough of the L bend in the bolt hole part. I'm thinking possibly about using a MAPP gas torch to heat it and try bending it in a vice with help from a hammer. if the results aren't good I will just have to spend money on the Wesco roadster belts. Howard Edited November 8, 20177 yr by 882993md Link to comment https://www.classiczcars.com/forums/topic/58895-seat-belt-release-attachment-point-correct-belts-for-260z/#findComment-534404 Share on other sites More sharing options...
November 11, 20177 yr comment_534575 I'm not sure about the belts, but it looks like your car has a Camaro steering wheel. Link to comment https://www.classiczcars.com/forums/topic/58895-seat-belt-release-attachment-point-correct-belts-for-260z/#findComment-534575 Share on other sites More sharing options...
November 11, 20177 yr comment_534579 3 hours ago, Freez74 said: I'm not sure about the belts, but it looks like your car has a Camaro steering wheel. That looks exactly like what my '72 Camaro LT had. Link to comment https://www.classiczcars.com/forums/topic/58895-seat-belt-release-attachment-point-correct-belts-for-260z/#findComment-534579 Share on other sites More sharing options...
November 11, 20177 yr comment_534580 Here's mine, 74 260 passenger side. Link to comment https://www.classiczcars.com/forums/topic/58895-seat-belt-release-attachment-point-correct-belts-for-260z/#findComment-534580 Share on other sites More sharing options...
November 11, 20177 yr comment_534590 I like my Wesco Roadster seatbelts which gives 3 point retractable and doesn't require any new fitting holes from the original belts. Skip the roadster belt hardware mounting kit and buy just 1 of these hardware kits instead. https://www.wescoperformance.com/2poresebehak.html The 2 "L" brackets are what you want for the buckle side of each belt. The rest of the mounting hardware can be re-used from the old belts. Edited November 11, 20177 yr by w3wilkes Link to comment https://www.classiczcars.com/forums/topic/58895-seat-belt-release-attachment-point-correct-belts-for-260z/#findComment-534590 Share on other sites More sharing options...
November 13, 20177 yr Author comment_534728 On 11/11/2017 at 6:30 AM, Freez74 said: I'm not sure about the belts, but it looks like your car has a Camaro steering wheel. I was forced to install the Camaro steering wheel as I have a mullet. Link to comment https://www.classiczcars.com/forums/topic/58895-seat-belt-release-attachment-point-correct-belts-for-260z/#findComment-534728 Share on other sites More sharing options...
November 13, 20177 yr comment_534791 9 hours ago, 882993md said: I was forced to install the Camaro steering wheel as I have a mullet. Got any mullets pics? Link to comment https://www.classiczcars.com/forums/topic/58895-seat-belt-release-attachment-point-correct-belts-for-260z/#findComment-534791 Share on other sites More sharing options...
