Posted November 10, 20177 yr comment_534544 I saw on Instagram this morning that someone I follow had a pair of Silvermine Motors Subaru r180 output shafts fail on him before they hit 5,000 miles. I was wondering if anyone has thoughts on the quality of these parts. Otherwise, these are the options: 1. The sane option is to get some output shafts that mate the stock half shafts to the Subaru differential. These seem to be limited to the Silvermine ones ($375) or the ones at Futufbab ($550). The Beta Motorsports ones seem to be NLA. 2. The insane option is to get the output shafts at Z Car Depot that mate a Subaru differential to a Porsche 930 CV axle as well as the CV-to-27-spline stub axle that they have ($1,220 for both), buy some 280ZX stub axels ($250 to 500 on eBay although I'm sure I can find them for less), and get some custom 930 axles made ($???) 3. The sketchy option is to get a CV conversion kit that works with what I have and stock Subaru output shafts ($$$ plus a lot of extra bolts and billet aluminum in my driveline). Edited November 10, 20177 yr by Matthew Abate Link to comment https://www.classiczcars.com/forums/topic/58932-anyone-have-subaru-output-axle-reviews/ Share on other sites More sharing options...
November 11, 20177 yr comment_534570 Matthew are you looking at putting a Subaru R180 in your car? Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/58932-anyone-have-subaru-output-axle-reviews/#findComment-534570 Share on other sites More sharing options...
November 11, 20177 yr Author comment_534572 Yes. I already have it.Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/58932-anyone-have-subaru-output-axle-reviews/#findComment-534572 Share on other sites More sharing options...
November 11, 20177 yr comment_534576 Which one did you get? What kind of issues have you run into?Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/58932-anyone-have-subaru-output-axle-reviews/#findComment-534576 Share on other sites More sharing options...
November 11, 20177 yr Author comment_534577 I haven't run it yet, but I got the 2014 3.9. I think it's the newest one that is limited slip (newer STIs have an open diff). So far what I've found is that you need the input flange and rear mounting studs from a Datsun. I got the studs along with a complete rear cover just in case the Subaru cover has clearance issues against the various parts that are in there. For example, the Subaru vent is really tall and might hit.I'll be swapping the covers and input flange right after I repaint the case. It was fairly rusty when I got it.Other than that, you just have to figure out if your going to use Datsun half shafts or CVs. CVs present their own complications, which I covered in my original post. Link to comment https://www.classiczcars.com/forums/topic/58932-anyone-have-subaru-output-axle-reviews/#findComment-534577 Share on other sites More sharing options...
November 11, 20177 yr comment_534587 On 11/10/2017 at 6:53 PM, Matthew Abate said: I saw on Instagram this morning that someone I follow had a pair of Silvermine Motors Subaru r180 output shafts fail on him before they hit 5,000 miles. I was wondering if anyone has thoughts on the quality of these parts. You should post the details of this "failure". It's not clear what failed. "Shaft" can mean the diff stub axle, the u-joint half-shaft, the CV axle, or even the hub axle depending on who's talking. Axle and shaft get used pretty much willy-nilly. http://www.silverminemotors.com/datsun/datsun-240z/drivetrain-17/lsd-r180-sti-out-output-flange-conversion-stub-axels https://zcardepot.com/r180-subaru-axle-set-to-930cv-joint-new.html Edited November 11, 20177 yr by Zed Head Link to comment https://www.classiczcars.com/forums/topic/58932-anyone-have-subaru-output-axle-reviews/#findComment-534587 Share on other sites More sharing options...
November 11, 20177 yr comment_534599 Matthew thanks for the info. I am really curious what Subaru that 2014 3.90 lsd came out of. I have been considering doing this switch over but only information that indicates the 3.90 only came in the 04-05 STI. Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/58932-anyone-have-subaru-output-axle-reviews/#findComment-534599 Share on other sites More sharing options...
November 11, 20177 yr Author comment_534601 On 11/11/2017 at 6:58 PM, 7tooZ said: Matthew thanks for the info. I am really curious what Subaru that 2014 3.90 lsd came out of. I have been considering doing this switch over but only information that indicates the 3.90 only came in the 04-05 STI. Sent from my iPhone using Classic Zcar Club mobileYou are correct. I mis-typed and have a 3.54, which is what I wanted because it's the stock ratio for the Z Link to comment https://www.classiczcars.com/forums/topic/58932-anyone-have-subaru-output-axle-reviews/#findComment-534601 Share on other sites More sharing options...
November 12, 20177 yr comment_534625 Contact John Williams on Facebook. He's the one who built the sti axels from the start. I have his axels in my car with a 3:9 Sti sure trac diff. Good guy to deal with. Edited November 12, 20177 yr by moelk Link to comment https://www.classiczcars.com/forums/topic/58932-anyone-have-subaru-output-axle-reviews/#findComment-534625 Share on other sites More sharing options...
November 13, 20177 yr comment_534699 The first side axle made to allow using the Subaru STI LSD in a 240Z with the stock drive axles was made by John Coffey at Beta Motorsports. John sold the design to Wolf Creek Racing. What Wolf Creek Racing has done with the design I do not know. I have John's side axles in my Z and they are holding up fine so far. I use my car for time trialing so the usage hours/milage are low but always at high loads and speeds. The engine is stock so the power level is moderate. Link to comment https://www.classiczcars.com/forums/topic/58932-anyone-have-subaru-output-axle-reviews/#findComment-534699 Share on other sites More sharing options...
November 13, 20177 yr comment_534715 On 11/13/2017 at 2:28 AM, beermanpete said: The first side axle made to allow using the Subaru STI LSD in a 240Z with the stock drive axles was made by John Coffey at Beta Motorsports. John Williams made these axels for John Coffey at Beta Motorsport. Link to comment https://www.classiczcars.com/forums/topic/58932-anyone-have-subaru-output-axle-reviews/#findComment-534715 Share on other sites More sharing options...
November 14, 20177 yr comment_534799 On 11/13/2017 at 8:37 AM, moelk said: John Williams made these axels for John Coffey at Beta Motorsport. Ah. I did not know that. Thank you. Link to comment https://www.classiczcars.com/forums/topic/58932-anyone-have-subaru-output-axle-reviews/#findComment-534799 Share on other sites More sharing options...
