Here are some pictures of the "Rusty Pig". This car came out of Miami and has a salvage title. I was a flood vehicle so I assume it was in the process of being painted then they had a flood.  I was hoping they wouldn't spend the time and paint to paint a "Rusty Pig" but I was mistaken
I believe it's been lowered. Haven't looked to see how they did it yet..
Rockers look bad and would really need some work
This is the part I hate most, the cowl area needs work...
Early air cleaner I believe. I believe the engine has been replaced. Also shouldn't it have the early valve cover...
20171118_152636.jpg20171118_152651.jpg20171118_152657.jpg20171118_152716.jpg20171118_152711.jpg
Some new door seals in the box...
20171118_152720.jpg20171118_152722.jpg20171118_152722.jpg20171118_152724.jpg20171118_152743.jpg20171118_152750.jpg20171118_152754.jpg20171118_152804.jpg
Rear pan is wrong. The replacement from Zedd Findings is inside the car
https://www.classiczcars.com/forums/topic/59014-hls30-07848/
11 hours ago, madkaw said:
Did you just acquire this ?
Yes, just got here last week. Many times these cars will start and run once they dry out and you change the fluids...
4 hours ago, grannyknot said:
On the last pic, is that the water line I see on the speedo & tach? That's a big project.
Probably, if you look at the drivers door picture the yellow line near the door handle is the water line...
Even if all the electrical were bad I have all of that here in spare parts. The rust is the bigger issue for me. I don't really want another big body and paint project...
Very nice! This is my kinda project. Rode hard and put away wet; Very wet.
That thing isn't rusty, I've shown you what rusty looks like. That hole in the side of the cowl is a bit strange. Get that fender off and have a look.
Edited by zKars
The bumper mounts are early 260 style I believe. 280's would have have big holes where the shocks stick through. 240's have a pair of holes for bolts, these have 3 threaded holes. ??
Good point on the valence and the fact there’s a spare valence laying in the hatch. Those are a PITA to fit also- no properly curved
Funny thing is the steering wheel looks like the exact one that was on 4858 that I acquired - if my memory is correct
I agree this car isn't a rusty as your latest but at that point I'm not sure it's a car. It might be a bunch of spare parts held together with rust... :P
1 hour ago, cbuczesk said:
If you look at the pics of the hatch opening you can see where the tail pan was spliced in.
Chuck
I noticed that there looks to be a good bit of filler in the rear hatch area where they normally rust. I guess it's possible they replaced the whole rear end with a 260z rear section. I will have to get underneath at some point to see if I can see what kind of signs I can find of welding
If you look a couple inches or so up the sides of the hatch opening you can see where it was welded. I noticed the filler too. I'm not sure what that's hiding.
Chuck
Sent from my Moto G Play using Classic Zcar Club mobile
