I have developed a small leak in my transmission.  It appears to be leaking from this point, the wires are wet, so I assume it is leaking internally and not from the threads.  Has anyone else seen this and if so how did you address?  Thanks!
https://www.classiczcars.com/forums/topic/59017-leaking-transmission-5spd/
