Posted November 23, 20177 yr comment_535687 My actual airtex 8012s electric fuel pump is barely 3 psi at the carbs. I found a stock spare one on my garage and would like to swap as i believe the metal filter could be clogged inside. During the process i would also like to replace the fuel lines that go in and out of the pump with new rubber hoses. I believe these lines are 5/16". Am i correct? Link to comment https://www.classiczcars.com/forums/topic/59030-fuel-lines-in-and-out-of-electric-fuel-pump/ Share on other sites More sharing options...
November 23, 20177 yr comment_535716 Flow line is yes, return is smaller, I think 3/16". Link to comment https://www.classiczcars.com/forums/topic/59030-fuel-lines-in-and-out-of-electric-fuel-pump/#findComment-535716 Share on other sites More sharing options...
