borini63 Posted January 4, 2018 Author Share #25 Posted January 4, 2018 Finally...The Z is alive and running off a gas can right now.The motor sounds healthy and solid.Got lucky there.....the Z been sitting since 2002 and I thought it has a bad engine.I had to replace the mechanical Fuel pump(the old one starts to leak). Also swapped to 280ZX Distributor...much efficient and way better than points!! 280ZX internal reg Alternator next. Such a releaf ...now I will jump to fix the clutch and brake system.so I can drive it around!! Scratched couple things from the long list....... Link to comment Share on other sites More sharing options...
borini63 Posted January 4, 2018 Author Share #26 Posted January 4, 2018 Just uploaded a video while she is running. Link to comment Share on other sites More sharing options...
tzagi1 Posted January 4, 2018 Share #27 Posted January 4, 2018 You are a tad advanced, retard it by a hair. Link to comment Share on other sites More sharing options...
JSM Posted January 5, 2018 Share #28 Posted January 5, 2018 2 hours ago, tzagi1 said: You are a tad advanced, retard it by a hair. I'm not knocking your assessment, but I'd love to know how you concluded that from the video? You don't know if the car was chocked or where the idle adjustment screw is set. Difficult to see from the vid, but idle looked around 8-900. Is this based on your intuition? Didn't sound like it was running a high idle? Link to comment Share on other sites More sharing options...
tzagi1 Posted January 5, 2018 Share #29 Posted January 5, 2018 By the sound the starter made, go to the vid and listen...that hiccup is a due to too much timing. That btw is how we used to set timing without a gun, keep advancing a little at a time Until it sounds like that...then retard it a notch and its set. (I know it's not the "proper" way....but in a pinch it works.) for example....changing a cam on a SBC in the auto parts store parking lot (Barstow CA circa 1988) with a tool kit that can fit in a woman's purse.. 1 Link to comment Share on other sites More sharing options...
JSM Posted January 5, 2018 Share #30 Posted January 5, 2018 To me the battery sounds weak. Oh well. I guess if Jamal throws a timing light on it we would know for sure. 1 Link to comment Share on other sites More sharing options...
tzagi1 Posted January 5, 2018 Share #31 Posted January 5, 2018 The starter spins fine, notice that the hiccup occurs when its starts only. Link to comment Share on other sites More sharing options...
gundee Posted January 5, 2018 Share #32 Posted January 5, 2018 Likely a used battery he put in for testing the engine. We really don't know its condition. A load test would tell. Also did you see he just set the battery cable on the post to start it? Its not even tightened yet. Link to comment Share on other sites More sharing options...
borini63 Posted January 5, 2018 Author Share #33 Posted January 5, 2018 Yeah a new battery but got weaken due to a lot of cranking to start before using the 280ZX Distributor, I will tighten the posts and recharge it. I will recheck the timing again tomorrow and get back to you guys.......When we did the timing we just lined up the magnet teeth thing inside the distributor(sorry I don't know what it's called) and made sure the balancer mark lined up with the arrow on the timing cover(there is no numbers plate there.....just an arrow plate). After that we just fire it up and Voalla the engine started. Still though I need to adjust the valves and again recheck the timing. Thanks guys for the replies. Link to comment Share on other sites More sharing options...
borini63 Posted January 5, 2018 Author Share #34 Posted January 5, 2018 I am wondering if I can use a 15/16 Brake master cylinder instead of the regular 7/8 master in my 240Z.I have 15/16 master laying around and just to save some money and maybe I will upgrade the brake system in the near future?? Link to comment Share on other sites More sharing options...
borini63 Posted January 10, 2018 Author Share #35 Posted January 10, 2018 On 1/4/2018 at 3:10 PM, tzagi1 said: You are a tad advanced, retard it by a hair. I think you are right...I will do that and report back. Link to comment Share on other sites More sharing options...
borini63 Posted January 10, 2018 Author Share #36 Posted January 10, 2018 You are right....it ran better when we timed her at 12 degree TDC @800 RPM. Link to comment Share on other sites More sharing options...
