borini63 Posted July 16, 2018 Author Share #73 Posted July 16, 2018 Here is the sound of the Muffler ......not bad for ebay one!! Link to comment Share on other sites More sharing options...
borini63 Posted July 16, 2018 Author Share #74 Posted July 16, 2018 (edited) Then I decide to swap my extra 280ZX 5Speed tranny to my 240Z....... I think I need to cut out the tranny tunnel to clear the shifter rod. What you guys think?? First..the 4speed out..... Then the 5 speed in and the shifter hole is too narrow.......also I had to cut the outlet exhaust pipe to clear the tranny......I am not worry because I will install a headers. Edited July 16, 2018 by borini63 Link to comment Share on other sites More sharing options...
borini63 Posted July 16, 2018 Author Share #75 Posted July 16, 2018 On 6/27/2018 at 8:17 AM, duffymahoney said: Got a link to the exhaust system? Here is one right now in Yahoo Japan.......three days left!! http://buyee.jp/item/yahoo/auction/u209182537 Link to comment Share on other sites More sharing options...
Patcon Posted July 16, 2018 Share #76 Posted July 16, 2018 I think most people heat a shifter rod and bend it to align with the hole. Most don't want to cut the tunnel because it creates other problems as well as being hard to repair. Search for some images or threads on Google Link to comment Share on other sites More sharing options...
borini63 Posted July 16, 2018 Author Share #77 Posted July 16, 2018 3 minutes ago, Patcon said: I think most people heat a shifter rod and bend it to align with the hole. Most don't want to cut the tunnel because it creates other problems as well as being hard to repair. Search for some images or threads on Google This Z is a 70 and I believe the later year models has a wider tunnel shifter opening....I already have a bent shift rod!! Link to comment Share on other sites More sharing options...
Patcon Posted July 17, 2018 Share #78 Posted July 17, 2018 bent like post #7 here or #58 here I know some people heat them and bend them instead of cut and weld Link to comment Share on other sites More sharing options...
tzagi1 Posted July 17, 2018 Share #79 Posted July 17, 2018 Back in the early 90's I also torch bent the rod, still had to make some slices and bend the sheet metal up to clear. Since I learned some new tricks. I would cut the rod right above the fulcrum and add a plate to move it back per diem, not that hard and no (body) cutting needed. Link to comment Share on other sites More sharing options...
borini63 Posted July 17, 2018 Author Share #80 Posted July 17, 2018 I think I will go with the 90 degree shift rod. I will keep you guys updated. Thanks 1 Link to comment Share on other sites More sharing options...
