2 minutes ago, Patcon said:
Does the 240 current sensing tach only have one loop out the back of the tach?
Yes.
Image 2 - Datsun 240Z 4-wire tachometer  OEM used
One thing I didn't experiment with was polarity. I can run more tests tomorrow.
Also, were you splitting current between two tachs or just the 510?
They were in series. That would be the same current since neither should be a load. I might be able verify that with an oscilloscope.
I ran a couple of more tests.
  1. Reversed polarity - Tachometer did not register at all.
  2. Original polarity - Tachometer in car registers just as it should.
  3. Tachometer on multimeter put in 4 cylinder mode - 510 tachometer seems to be reading about 1/10 of the multimeter. The needle did appear to indicate proportionally.
4 minutes ago, Patcon said:
Is there something in the tach that would reduce the current by 90%? Too much resistance on the loop or a bad component on the board?
I doubt it's resistance in the ignition circuit. It would have to be something internal to the tachometer. I don't know enough about inductive loop tachometers to say what, though.
This article on Dime Quarterly is interesting: http://dimequarterly.blogspot.com/2011/08/tech-how-to-510-factory-tachometer.html
It says the sensing should be done on the negative side of the coil, and it does mention polarity for the sensing.
I'm not sure if I will have time to run another test today. We'll see.
My thoughts? If the two tachs were in series and the one in the dash worked fine, then I think there is an internal problem with the 510 tach. I mean, there's a slight possibility it has something to do with the ballast resistor, but I suspect the gauge itself.
I also think there is nothing to be gleaned from the seeming "proportionality" of the tach readings. I think that's a red herring.
Steve, If you want to send me that tach, I'll open it up and do some reverse engineering on the guts? If nothing else, it'll be a great story about a tach that traveled all over the country. "510 Tach Tour!"    LOL
I'll try wiring it like it suggests on Dime Quarterly, and if it doesn't behave better, I can send it to you.
Not surprisingly, there was no change. But I did take the time to mark the polarity on the tachometer wires to make it easier to identify which wire goes where in the future. I couldn't find my red electrical tape (that had been sitting in the same place in the garage for about 10 years until I reorganized last year), but I did find some red heat shrink that fit over the spade connector.
At least I had fun testing. I'm interested in Bruce's analysis. I could do a visual on the discrete components, but I think Bruce has better skills in that realm.
Edited by SteveJ
Well this may all be for naught... I got a head start based on the pics from that Dime Quarterly thread I started looking for info on the IC chip - AN603.
Based on the logo, it looks like a Matsushita (now part of Panasonic) part, but I couldn't dig up any info about it at all. So if I can't find anything about what's going on inside that chip, I might not be able to do much with it. I mean, I can certainly do a macro level reverse engineering and infer what's going on inside that chip, but that may be about it.
And if it looks like there's something wrong inside the chip, I certainly won't be able to get a replacement except from another old donor part.
I wonder if they used that same chip in the current sense Z tachs... Those are at least easier to find at this point.
Anyway, regardless, I'll do what I can.
