Posted December 4, 20177 yr comment_536601 I’m seriously considering a disk brake conversion for my ‘72 240z, what are some good kits that are relatively cheap and what problems will I encounter doing this conversion, thanks. Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/forums/topic/59097-rear-disk-brake-conversion/ Share on other sites More sharing options...
December 4, 20177 yr comment_536604 Someday I'd like to get this one from zcardepot.com https://zcardepot.com/disc-brake-conversion-rear-disk-240z-260z-280z-1331.html here's some conversations you could read https://www.google.com/search?rlz=1C1BOFA_enUS494US494&ei=cWklWoaSNofx_AbOkKWwBA&q=zcardepot+rear+disc+conversion+classiczcars.com&oq=zcardepot+rear+disc+conversion+classiczcars.com&gs_l=psy-ab.3...7908.13226.0.13699.17.17.0.0.0.0.169.2075.1j16.17.0....0...1c.1.64.psy-ab..0.16.1967...33i160k1j33i21k1j33i13i21k1.0.5CSX_hdkky0 Link to comment https://www.classiczcars.com/forums/topic/59097-rear-disk-brake-conversion/#findComment-536604 Share on other sites More sharing options...
December 4, 20177 yr comment_536607 If any kit requires you to give up your parking brake and you have a manual trans- you might think twice. I miss my parking brake and it adds to the cost in most disc upgrades . Bigger front discs and rear drums in excellent condition should be adequate for all but racing Link to comment https://www.classiczcars.com/forums/topic/59097-rear-disk-brake-conversion/#findComment-536607 Share on other sites More sharing options...
December 4, 20177 yr comment_536611 I used the upgrade kit from Arizona Z. Very good quality and they were easy to work with. Very pleased with the performance as compared to the stock brakes. Probably not the cheapest solution but it was brand new and in the limit performed extremely well. You will need to consider the following: 1. If you are running the standard 14 inch rims, they will not fit over the big brake kit. I have been told that 15" will work, but in my case I went with a 16" Konig rewind. You will also need to consider what you will want to do for a spare tire. I ended up getting a donut spare I believe from a later model Nissan Sentra that had the correct bolt spacing and also fit into the spare tire well. It easily fits over the bigger brakes. 2. At least with the Arizona Z kit, you will need to decide what to do for a emergency / parking brake. The Arizona kit as standard, does not include a replacement for the e-brake. They do sell a mechanical caliper which can be used to replace the OEM e-brake, but they only provide the caliper itself as well as a different mounting bracket. I had to design a method for connecting the e-brake to the brake handle and this was not straight forward. I have been meaning to do a write up on my implementation of this for some time but just haven't gotten around to it yet. If you decide to go in this direction, let me know and I'll get the write up done. Hope that helps. Mike. Link to comment https://www.classiczcars.com/forums/topic/59097-rear-disk-brake-conversion/#findComment-536611 Share on other sites More sharing options...
December 4, 20177 yr comment_536631 The AZC rear brake kit is very nice and will work well with a 15/16th master cylinder, but the additional rear park brake system is currently not available and after over a year of inquiring, I am beginning to give up hope that they will be making them again.... Link to comment https://www.classiczcars.com/forums/topic/59097-rear-disk-brake-conversion/#findComment-536631 Share on other sites More sharing options...
December 5, 20177 yr comment_536669 10 hours ago, siteunseen said: Someday I'd like to get this one from zcardepot.com https://zcardepot.com/disc-brake-conversion-rear-disk-240z-260z-280z-1331.html i have this one. it works well. downside, no instructions at all, and, you dont know what parts they are when you need replacements. and, 14" wheels do fit, but there is very little extra room. IIRC i had to remove the wheel weights. i also have the toyota front calipers, but not these wheels now Edited December 5, 20177 yr by sweatybetty Link to comment https://www.classiczcars.com/forums/topic/59097-rear-disk-brake-conversion/#findComment-536669 Share on other sites More sharing options...
December 5, 20177 yr comment_536705 That looks like the maxima caliper. So they are 1984 Nissan Maxima calipers. This is the same swap I am doing. I found the bracket online for like 65. Then I bought the rebuilt calipers, bolts right on. You keep the E brake. Link to comment https://www.classiczcars.com/forums/topic/59097-rear-disk-brake-conversion/#findComment-536705 Share on other sites More sharing options...
December 5, 20177 yr comment_536713 is there a real need to swap the rear brakes? disc conversions just weigh loads. Drums are more than good enough for anything but 10/10th's racing. Link to comment https://www.classiczcars.com/forums/topic/59097-rear-disk-brake-conversion/#findComment-536713 Share on other sites More sharing options...
December 5, 20177 yr comment_536718 I agree, IF the drum brakes are well maintained. Link to comment https://www.classiczcars.com/forums/topic/59097-rear-disk-brake-conversion/#findComment-536718 Share on other sites More sharing options...
December 5, 20177 yr comment_536720 The more serious point is that I don’t know of any calipers at all that are cooler than finned drums. Link to comment https://www.classiczcars.com/forums/topic/59097-rear-disk-brake-conversion/#findComment-536720 Share on other sites More sharing options...
December 5, 20177 yr comment_536724 I hate drums:) But I am sure they are fine for 99.9% of people. Link to comment https://www.classiczcars.com/forums/topic/59097-rear-disk-brake-conversion/#findComment-536724 Share on other sites More sharing options...
December 5, 20177 yr comment_536727 28 minutes ago, duffymahoney said: I hate drums:) But I am sure they are fine for 99.9% of people. Why do you hate them? I too have been mulling over this subject for my 280z since I am replacing everything in the suspension. The previous owner threw in the Toyota front discs and I can still lock up all 4 tires if I hammer on the brake pedal. So I don't see how adding bigger brakes + discs would benefit me unless I am at the track since right now I seem to get enough braking power. Edited December 5, 20177 yr by AlbatrossCafe Link to comment https://www.classiczcars.com/forums/topic/59097-rear-disk-brake-conversion/#findComment-536727 Share on other sites More sharing options...
