240260280 Posted October 26, 2019 Author Share #37 Posted October 26, 2019 There is enough evidence in the similarity of the parts alone to convince anyone of a strong relationship between the two. It is not convergent evolution. It also happened before the Prince merger so the design could not have been acquired via that path. Finally the strong or loose interpretation of the Nostalgic Hero article seems to seal the matter. If I had the magazine article I could get a friend in Osaka to translate it to get a clearer picture however, I have faith in Carl's research. Bottom line is that the L engines have a strong resemblance to the Mercedes M-180 engine. I think this is a good thing! Link to comment Share on other sites More sharing options...
240260280 Posted October 26, 2019 Author Share #38 Posted October 26, 2019 (edited) On 12/12/2017 at 5:05 AM, HS30-H said: What's not being discussed here is the big layout difference. The Mercedes M180 engine was conceived and designed primarily for use in LHD vehicles, whilst the Nissan L-gata range was conceived and designed primarily for use in RHD vehicles. Mercedes M-180 for LHD. The L-gata head is same non-cross flow and basically mirrored. Not a big change. The alternator and starter are even on the same side. The M180 also has the shared intake/exhaust manifold fastener design and coolant entry location. M180 distributor is in the same location. Oil filter location was flipped to other side on the L-gatta and moved forward as a starter was on the mirrored location. Even the same inline Distributor, Spindle, Oil Pump configuration with worm gear drive. Edited October 26, 2019 by 240260280 Link to comment Share on other sites More sharing options...
HS30-H Posted October 26, 2019 Share #39 Posted October 26, 2019 51 minutes ago, 240260280 said: Mercedes M-180 for LHD. The L-gata head is same non-cross flow and basically mirrored. Not a big change. The alternator and starter are even on the same side. Except that the starter position for the first L20 six was on the left side of the engine. 52 minutes ago, 240260280 said: The M180 also has the shared intake/exhaust manifold fastener design and coolant entry location. Except the thermostat housing/top radiator hose on the first L20 six, and even on the early L20A, was in the middle of the 'head on the left hand side. Fuel pump location/drive is also different. 55 minutes ago, 240260280 said: Even the same inline Distributor, Spindle, Oil Pump configuration with worm gear drive. Except the drive for the distributor/oil pump jackshaft on the M180 is not taken direct from the crank snout as it was on the L-gata. I think there's a certain amount of confirmatory bias at play here. Yes, the cam towers, finger cam followers, follower pivots & springs, oil spray bar etc are very similar and there are close cribs of details to do with the distributor/oil pump jackshaft, but there are also numerous differences both large and small. The Nissan L-gata is not a direct copy of the M180, is it? Link to comment Share on other sites More sharing options...
HS30-H Posted October 26, 2019 Share #40 Posted October 26, 2019 (edited) 1 hour ago, 240260280 said: ...I have faith in Carl's research. If you read through the thread I linked to earlier, you'll see why I'm a little bit more cynical. Edited to add: You're exercising yourself to show how similar the M180 was to the Nissan L-gata, and also saying you have 'faith' in Carl's research. Meanwhile Carl was spending a lot of energy trying to push his view that Hiroshi Iida's 1964/5 L20 six was quite a different animal from the '1966' L16 and L24 and that the L16 and L24 were effectively 'clean slate' designs not related to, or evolved from, that L20 six. So, what's the M180 closest to? The 'original' L20 six, or the came-out-of-nowhere-just-for-the-USA L16 and L24? If you concur with Carl's 'research', it has to be one or the other, and not both because he says they are "not related". See how silly all this 'made-for-the-USA' stuff gets? Edited October 26, 2019 by HS30-H addition Link to comment Share on other sites More sharing options...
240260280 Posted October 27, 2019 Author Share #41 Posted October 27, 2019 (edited) @HS30-H interesting input for sure. I have never viewed the OHC and valve train of the original L20. What does it look like? It is possible the initial influence was in the head for the original L20 then a trickle down to the L12/20/24 block after problems popped up in the original L20 short block. Edited October 27, 2019 by 240260280 Link to comment Share on other sites More sharing options...
HS30-H Posted October 27, 2019 Share #42 Posted October 27, 2019 11 hours ago, 240260280 said: I have never viewed the OHC and valve train of the original L20. What does it look like? Bearing in mind that Carl Beck asserted this... "I on the other hand see evolution as a distinct series of small incremental changes, leading from the origin to the current example. I see no such incremental progression between the L20 and L20A. Rather I see a completely different engine, unlike any that Nissan had ever produced before - pop up out of nowhere - with the appearance of the L16 in late 67 as specified for the PL510 in 1966. I do see clear incremental evolution from the L16 to the L13 (same block de-stroked & head) and then to the L24 (same block/head with two additional cylinders) and L20A (same block design / head design cast in a smaller bore, and in some cases with small main bearing supports) all sharing a visibly common design, quite different from the Mercedes looking L20 of 65." ...I'm wondering where you will go with your "our cars have Mercedes engines!" line of thinking. Carl says that - in effect - the L20 six and the L16/L24 are 'not related'. If that was the case (hint: it's nonsense...) then what...? Link to comment Share on other sites More sharing options...
HS30-H Posted October 27, 2019 Share #43 Posted October 27, 2019 Hiroshi Iida explained that the L20 six was designed and engineered within a very short period (certainly shorter than would have been ideal) largely in response to the activities of Nissan's competitors (Toyota's Crown six and Prince's G7 six) whilst the L13/L16 fours had the benefit of what had been learned from that L20 six and the benefit of new technology and equipment then coming on line - most especially the volume pressure die-casting machinery which allowed the engineers to design componentry that was previously not feasible. Iida saw the 'new' fours as an evolution of the L20 six and Nissan classed them as being in the same family (clue: 'Lxx'), even to the extent of sharing workshop manuals and parts lists. The L20A got that 'A' suffix simply to differentiate it from the earlier L20 six, and there was even a point at which Nissan was fitting both L20 sixes and L20As in the same series of cars. They are the same family. The whole point of the 'L-gata Module' was standardisation of settled specs and componentry. It made sense to do this with the L13/L14/L16/L20A/L23/L24 etc as they now had a core design which could share specs, components and ancillaries to lower costs and increase efficiency. The fact that the L13 & L16 came after the L20 six is what allowed them to benefit from what was happening within Nissan - and within Japan - during a key period. Yes, Hiroshi Iida and his colleagues at Nissan were clearly 'inspired' by certain elements of the MB engines, but I would not class it as a wholesale 'copy'. There's clear evidence of evolution in thinking and making use of newer technology in manufacturing and processing there, not to mention the requirements of their single biggest market (yes, JAPAN). Here's what Carl apparently believes about the drivers here: I believe that it was revolution, and that was driven by Mr. K in America, Nissan Motors need to increase production by increasing Export Sales, the merger with Prince Motors and the restructuring of the in-house design department - all of which converged at Nissan in the 65/66 time frame and resulted in the creation of something totally new for Nissan. The first outcome of that revolution in Design and Engineering related to new engines was the U20, followed by the L16 in the PL510, and then the L24/L20A. I've said it before and I'll say it again, unless you try to understand Nissan's situation in the Japanese market - as well as the wider Japanese market itself - you will never fully understand the "Mr K in America" situation for what it really was. It's almost as though the people pushing that "made for the USA" schtick can't imagine that Japanese society had its own journey of progression, of improvement, or it's own hopes and dreams. What of the people actually designing and making the stuff "for the USA"? Do you think their ambition was to own a 998cc corned beef can on wheels, and to stop there? Look at the above quote. You see that "L16 in the PL510" bit? Can you see the chauvinism in that statement? Its like he thinks the L16 would not have existed but for an LHD (and presumably American) model. Doesn't matter that the L13 was designed and built at the same time, or that the L16 was sold in Japan too (and in greater numbers). It's "for the USA". Doesn't matter that the 510 was yet another step in Japan's journey to self betterment, or that - just like Nissan's other models of the period - just as much effort was put into the domestic versions as was put into the export versions, it was "for the USA". That's what they want to hear, isn't it? Here's a little quiz question: Which do you think is the bigger number, L-gata 'family' engines sold in Japan, or L-gata 'family' engines sold outside Japan? Link to comment Share on other sites More sharing options...
240260280 Posted November 28, 2019 Author Share #44 Posted November 28, 2019 (edited) From a reputable Motorsports Magazine: As an aside, Nissan's development team in the first half of the 1960s eagerly studied German engines. In the same way as for the Prince, the former preferred Mercedes and the latter preferred BMW. Of course, the L type uses the counter flow method learned from the Mercedes type. It can be said that the good productivity is reflected in the original design of Nissan. On the other hand, what I learned from BMW seems to have been reflected in the G engine. L20 Head Edited November 28, 2019 by 240260280 Link to comment Share on other sites More sharing options...
240260280 Posted November 28, 2019 Author Share #45 Posted November 28, 2019 (edited) 1963 Prince G7 SOHC non-crossflow reference: G7B non-crossflow with triple Webers Edited November 28, 2019 by 240260280 Link to comment Share on other sites More sharing options...
HS30-H Posted November 28, 2019 Share #46 Posted November 28, 2019 9 minutes ago, 240260280 said: From a reputable Motorsports Magazine: As an aside, Nissan's development team in the first half of the 1960s eagerly studied German engines. In the same way as for the Prince, the former preferred Mercedes and the latter preferred BMW. Of course, the L type uses the counter flow method learned from the Mercedes type. It can be said that the good productivity is reflected in the original design of Nissan. On the other hand, what I learned from BMW seems to have been reflected in the G engine. L20 A Head That's an L20, not an L20A. Link to comment Share on other sites More sharing options...
HS30-H Posted November 28, 2019 Share #47 Posted November 28, 2019 8 minutes ago, 240260280 said: 1963 Prince G7 SOHC non-crossflow reference: That's a 1965 G7B. 1 Link to comment Share on other sites More sharing options...
240260280 Posted November 28, 2019 Author Share #48 Posted November 28, 2019 35 minutes ago, HS30-H said: That's a 1965 G7B. Thanks for the corrections. I did some further checks and it seems the G7B has a crossflow head? The drawing above only shows the outline of the "invisible" exhaust manifold (you really have to look for it) on the left side of the head below the intake; so the above drawing seems to be the earlier G7 without crossflow? Link to comment Share on other sites More sharing options...
