Do you have it separeted from the dashboard? If so there should be 2 small screws that hold the metal section to the plastic section. After they are removed it will probably take a bit of a twist back and forth to get it to separate. Good luck.
esmit208,  Thanks for the reply. I did get the tack to come out. It was stuck to the case , looked like something had been spilled or leaked and stuck to the back of the tach and the case. Anyway it came out in one piece.
Thanks again.
