Posted April 30, 200321 yr comment_35660 I am putting a small-block Chevy in my 72 240, I also read that heat build-up under the hood could be a problem, so Ihad planned to put hood vents from a 260 on the 240 hood. Before I hack-up the good 240 hood, I wonder if a 260 hood would fit on a 240???? Figure someone has tried, any luck??:bandit: Link to comment https://www.classiczcars.com/forums/topic/5920-hood-swap/ Share on other sites More sharing options...
April 30, 200321 yr comment_35661 in regards to the hoods, swap away. 1970-78 will all fit. as for the small block chevy why not just leave it stock and build what you have :classic: Link to comment https://www.classiczcars.com/forums/topic/5920-hood-swap/#findComment-35661 Share on other sites More sharing options...
April 30, 200321 yr comment_35677 cus he wants 300 + hp and 350 ft lbs of torque from a stock engine with a few bolt ons like intake and headers... thats whyLOL all the hood are interchangeable from 70-78...for eight yrs hoods, headlight buckets, fenders and doors were all the same except the later years of doors are heavier because of side impact braces. Link to comment https://www.classiczcars.com/forums/topic/5920-hood-swap/#findComment-35677 Share on other sites More sharing options...
April 30, 200321 yr comment_35678 I meant to say nine yrs:bunny: Link to comment https://www.classiczcars.com/forums/topic/5920-hood-swap/#findComment-35678 Share on other sites More sharing options...
April 30, 200321 yr comment_35681 psimkin,i have a 350 chevy 72... hauls assLOL what kind of tranny r u going to use? The reason I ask is because if u go with a T-5 tranny you do not have to remove the tranny mounts in the tunnel. I am running a th-350 tranny myself which did require the removal of the mounts in the tunnel. Link to comment https://www.classiczcars.com/forums/topic/5920-hood-swap/#findComment-35681 Share on other sites More sharing options...
May 1, 200321 yr comment_35821 The T-5 tranny is a manual right?Found in a camaro?I know if i go the V8 route in one of my ZsI want a manual. Link to comment https://www.classiczcars.com/forums/topic/5920-hood-swap/#findComment-35821 Share on other sites More sharing options...
May 2, 200321 yr comment_35829 yep... Link to comment https://www.classiczcars.com/forums/topic/5920-hood-swap/#findComment-35829 Share on other sites More sharing options...
May 15, 200321 yr Author comment_37547 Hey; psimkin here, sorry I didnt get back sooner, but Disneyland was great. To let you know, I am going with a built 700R4, 4spd auto. I designed the car for cruising, slightly fast cruising :bandit: I built the small block for the reason stated by 72Z, more balls. I have been busy at work, but I am taking the car to a buddys shop in the next couple of days to put all the pieces together, should be on the road by August, the wait is Killing me!!!!!:devious: Link to comment https://www.classiczcars.com/forums/topic/5920-hood-swap/#findComment-37547 Share on other sites More sharing options...
