March 12, 20187 yr comment_544373 Being a "4 spoke 'old school' fool" for wheels---- I had been intrigued for some time by this statement from Eric Neyerlin on his website: "This wheel (pn 40303-N3200) is the only OEM wheel that Nissan specifically produced for the 70-78 240Z-260Z-280Z (S30) models world wide. Nissan parts catalog shows a 4/73 production date for this design. Though common to most S30 models sold in Australia, Canada? and Europe this wheel was not offered stock on any US imported Z cars except for one year on the 1977 Black Pearl special edition model. Now, 46 years after the 240Z models were first introduction, this rare factory wheel is increasingly regarded as the the only true, period correct, vintage factory aluminum wheel to put on a meticulously restored S30 model, apart from original, model year correct, steel wheels and hub caps common to US models." Well---OK--- I'm in------- This is one of the set of 6 that I recently purchased. All of the wheels are in truly incredible condition, extremely clean inside and out and 4 of them are polished very well. I had a NOS set of center caps on hand from years ago that were destined for use on a set of "iron cross" wheels I owned at the time. The caps fit perfectly on these wheels and I've always liked the factory Nissan "acorn" style lug nuts with the captured washer. A substantial nut with positive fitment between the wheel and the lug. If the stated original production date of 4/73 is correct, then it is entirely conceivable that my 6/73 240Z could correctly have worn these in that same year. As period correct as I can get for this car and I don't have to risk losing my hubcaps-----been there and done that. I love the American Racing Equipment "Libre" rims currently on my car, but they are an American aftermarket rim. Seeing the "Nissan" stamp in the metal makes this "all right". Link to comment https://www.classiczcars.com/forums/topic/59262-2018-what-did-you-do-towith-your-z-today/?&page=4#findComment-544373 Share on other sites More sharing options...
March 12, 20187 yr comment_544376 I’m a big fan of your period correct American Libre wheels. In the early 70’s, people would notice all Z’s, but when one came by lowered, front and rear BRE spoilers and a set of Libre wheels (made famous by Morton and Brock) and an aftermarket exhaust that sounded like Road Atlanta, it made them want to go out and buy one. Nothing wrong with a well restored Z with skinny tires and hubcaps, but what gets my juices flowing is the stuff that makes you feel like you ARE John Morton. IMO Zup, keep those Libres .......they are period correct. Edited March 12, 20187 yr by Diseazd Link to comment https://www.classiczcars.com/forums/topic/59262-2018-what-did-you-do-towith-your-z-today/?&page=4#findComment-544376 Share on other sites More sharing options...
March 12, 20187 yr comment_544413 Nice wheels. They are different than what I expected, an optical illusion for a first timer's view. Link to comment https://www.classiczcars.com/forums/topic/59262-2018-what-did-you-do-towith-your-z-today/?&page=4#findComment-544413 Share on other sites More sharing options...
March 17, 20187 yr comment_544790 On 3/10/2018 at 5:00 PM, Patcon said: Guy, What technique did you use? Patcon.....I got around to removing the glue from my windows. I masked everything off and put down drop clothes and used this stuff with 000 steel wool. Only took an hour to do all 5 windows.....ammonia will work, but not nearly as good as Goof Off. 000 steel wool won’t scratch the windows.....several layers of removal followed by window cleaner. My windows have never been cleaner! Link to comment https://www.classiczcars.com/forums/topic/59262-2018-what-did-you-do-towith-your-z-today/?&page=4#findComment-544790 Share on other sites More sharing options...
March 17, 20187 yr comment_544793 I met the guy that invented Goof Off at a paint show in Atlanta in the late 80s. He was just a drunkard commercial painter that repainted apartment units but he knew Ronsonol alcohol would get latex paint off switch plates and other hardware. He mixed up some Ronsonol with acetone and called it Goof Off because you could goof off and paint but be able to clean up the mess. After that show he sold it off and now he's a bizillonaire is what we heard (probably dead by now though). He was wearing painter's over-alls too, loud and funny guy. Good story I'll always remember. Link to comment https://www.classiczcars.com/forums/topic/59262-2018-what-did-you-do-towith-your-z-today/?&page=4#findComment-544793 Share on other sites More sharing options...
March 21, 20187 yr comment_545280 Mocking up a template for a heat shield. Link to comment https://www.classiczcars.com/forums/topic/59262-2018-what-did-you-do-towith-your-z-today/?&page=4#findComment-545280 Share on other sites More sharing options...
March 21, 20187 yr comment_545281 On 3/21/2018 at 8:12 PM, moelk said: Mocking up a template for a heat shield. Wish I was there. Two key design points: 1. You want the manifolds to be hot. 2. You want the carbs to be cold. So, if the shield is not touching the carbs. it will help keep them cool. You can significantly lower the side near the air horns so that the hot air from the header flows along the shield towards the manifold at idle. Edited March 21, 20187 yr by 240260280 Link to comment https://www.classiczcars.com/forums/topic/59262-2018-what-did-you-do-towith-your-z-today/?&page=4#findComment-545281 Share on other sites More sharing options...
March 21, 20187 yr comment_545282 Thanks for the advice. This one will be with a little bend under the air horns. It will be mounted using the empty holes at the side of the carbs. It will sit 1 cm below the carbs. But I will probably end up with a solution looking like this for the second version: Link to comment https://www.classiczcars.com/forums/topic/59262-2018-what-did-you-do-towith-your-z-today/?&page=4#findComment-545282 Share on other sites More sharing options...
March 21, 20187 yr comment_545283 On 3/21/2018 at 8:35 PM, moelk said: Thanks for the advice. This one will be with a little bend under the air horns. It will be mounted using the empty holes at the side of the carbs. It will sit 1 cm below the carbs. But I will probably end up with a solution looking like this for the second version: So that makes two different devices: 1. Heat shield: to keep manifold heat away from carbs. 2. Cold air intake: to direct cold air from front of car into carbs. You can consider doing both Chimney-like bending of heat shield can be used to direct hot manifold air to 77 and later 280z hood vents. Link to comment https://www.classiczcars.com/forums/topic/59262-2018-what-did-you-do-towith-your-z-today/?&page=4#findComment-545283 Share on other sites More sharing options...
March 21, 20187 yr comment_545284 Or just buy my CAI and be done with it Link to comment https://www.classiczcars.com/forums/topic/59262-2018-what-did-you-do-towith-your-z-today/?&page=4#findComment-545284 Share on other sites More sharing options...
March 21, 20187 yr comment_545285 On 3/21/2018 at 8:48 PM, 240260280 said: So that makes two different devices: 1. Heat shield: to keep manifold heat away from carbs. 2. Cold air intake: to direct cold air from front of car into carbs. You can consider doing both Yepp I will make two different shields. Hope to find some time for it that’s the biggest problem. Link to comment https://www.classiczcars.com/forums/topic/59262-2018-what-did-you-do-towith-your-z-today/?&page=4#findComment-545285 Share on other sites More sharing options...
March 21, 20187 yr comment_545286 On 3/21/2018 at 8:54 PM, madkaw said: Or just buy my CAI and be done with it Nice but to much “bling” for my taste. Link to comment https://www.classiczcars.com/forums/topic/59262-2018-what-did-you-do-towith-your-z-today/?&page=4#findComment-545286 Share on other sites More sharing options...
