Mine is what MSA calls a stage 3 like Moelk's.
It's Schneiders 270/80F grind.  Sounds like I'll be using the E31 as I've planned all along. I'm not looking forward to grinding those .190" lash pads down to size, I think will be .175 or .180.
Thanks guys!
2 hours ago, psdenno said:
Looks good.  How much space between the seat and steering wheel? It looks like it sits a bit higher than stock
It does sit higher. I added all the plastic spacers on the bottom mounting studs. Easier for this these old legs to get in and out.
rebuilt 15/16 brake master cylinder
installed:
-- new rear brake hoses
-- new calipers
-- new brake booster
-- new brake master
-- new clutch master
-- new clutch slave
-- new clutch hose
-- new hose clips
Janet!  I need you to help bleed the clutch!
Waiting on front brake hoses to finish the brake job.  All new hydraulics will be a treat.  Blue always had a leaking booster so power brakes for a change will be nice.
- brembo brake rotors weathered the 10 years in the elements nicely; just surface rust
- Sumitomo S-12 calipers has rusted body and seized pistons
- clutch slave had rusted pin and a slight leak
- clutch master had a slight leak
- brake master had the top caps rusted
- rear drum brakes were great
Edited by 240260280
Mechanical:
- Valves adjusted
- Cam looks fine
- Made new gaskets for oil bar
Electrical:
- Tail lights now work
- Key  now starts car
- New alternator now charges battery
On Deck:
- about to practice Mig welding with C25 for first time.... holes in floor be warned!
350km total drive to and home from a car meet today. Over 30 degrees celsius. Car didn’t hesitate even once. The heat shield i built for the carbs workes i guess. I on the other hand was sweating like a ——————
A5F46C5C-793A-476E-AA87-F0D37A3A66EC.jpeg17168ADA-F3ED-49B7-8543-A663D8EF90C6.jpegD2AA9C58-68B1-4CB5-8853-B539711F803B.jpegDC9E29EC-844C-43F5-A813-78F83339F5EC.jpeg664674BD-3E3C-46F7-B6B7-AC8539E8FC0A.jpeg
Edited by moelk
