Posted January 1, 20187 yr comment_538792 I accept crypto currency. I'm always open to trades. More pics upon request. Brand New 40dcoe 151's with black texture powder coated cannon intake, Datsun Spirit heat shield powder coated black texture and Datsun Spirit fuel delivery pipe gold anodized. "How to build and power tune Weber and Dellorto" book. $1700 shipped conus. One black texture powder coated valve cover, one black texture powder coated oil pan, and one red wrinkle powder coated valve cover. $50 each shipped conus Early 280 5-speed. $150 shipped conus. I bought this transmission a couple of years ago from a member of HybridZ as a recent overhaul. It sat for a couple of years in my garage before I got a chance to install it. After installation everything worked fine, shifted smooth, except 5th gear. It will go in to fifth gear just fine without the engine running, but won't go in to fifth while driving. I removed the transmission and disassembled it to inspect for damage but did not find anything obvious without further disassembly. I didn't want to disassemble it further so I decided to upgrade to an SX 5-speed. I used this front case for my new 5-speed so this one will come with a 4-speed front case that will need to be machined to accept the reverse light switch in the correct location. I will throw in an early 4-speed input shaft assembly also so you can make a frankentranny if so desired (I was planning on doing this to go with my 3.36 rear gears instead of swapping out the rear end). Link to comment https://www.classiczcars.com/forums/topic/59282-sold-triple-webers-5-speed-and-more/ Share on other sites More sharing options...
January 1, 20187 yr comment_538802 hmm I don't see the brass of the sychro on the 5th. Link to comment https://www.classiczcars.com/forums/topic/59282-sold-triple-webers-5-speed-and-more/#findComment-538802 Share on other sites More sharing options...
January 1, 20187 yr Author comment_538803 the early 5 speeds didn't have a brass syncro, I believe its steel. Link to comment https://www.classiczcars.com/forums/topic/59282-sold-triple-webers-5-speed-and-more/#findComment-538803 Share on other sites More sharing options...
January 1, 20187 yr comment_538816 that weber setup looks great. almost as good as this BCH. ha Link to comment https://www.classiczcars.com/forums/topic/59282-sold-triple-webers-5-speed-and-more/#findComment-538816 Share on other sites More sharing options...
January 7, 20187 yr Author comment_539135 Apparently sometimes the early shifters will make contact with the later transmissions typically for first third and fifth. Looks like mine was only affecting the shift to fifth so there was no need to disassemble the tranny . The transmission is no longer for sale for $150. Don't forget...free shipping in the continental US on everything else. Link to comment https://www.classiczcars.com/forums/topic/59282-sold-triple-webers-5-speed-and-more/#findComment-539135 Share on other sites More sharing options...
January 9, 20187 yr comment_539319 On 1/7/2018 at 1:51 AM, torynich said: Apparently sometimes the early shifters will make contact with the later transmissions typically for first third and fifth. Looks like mine was only affecting the shift to fifth so there was no need to disassemble the tranny . The transmission is no longer for sale for $150. Don't forget...free shipping in the continental US on everything else. Is the red valve cover still available? Are the letters gold or is that an optical illusion in the pictures?Sent from my Pixel 2 XL using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/59282-sold-triple-webers-5-speed-and-more/#findComment-539319 Share on other sites More sharing options...
January 10, 20187 yr Author comment_539350 I glass beaded and alodined all the aluminum before powder coating then on the valve covers I removed the powder coat from the lettering with a scotchbrite disk on my diegrinder and then re alodined the bare aluminum. Alodine is a chemical conversion coating for aluminum used for corrosion control and is gold in appearance. (Alodine is different from anodized) The aluminum could be polished to a high silver luster still if so desired. The red valve cover is still available. Link to comment https://www.classiczcars.com/forums/topic/59282-sold-triple-webers-5-speed-and-more/#findComment-539350 Share on other sites More sharing options...
January 24, 20187 yr comment_540644 On 1/10/2018 at 3:28 AM, torynich said: I glass beaded and alodined all the aluminum before powder coating then on the valve covers I removed the powder coat from the lettering with a scotchbrite disk on my diegrinder and then re alodined the bare aluminum. Alodine is a chemical conversion coating for aluminum used for corrosion control and is gold in appearance. (Alodine is different from anodized) The aluminum could be polished to a high silver luster still if so desired. The red valve cover is still available. Interested in red valve cover. Is transmission still available? Link to comment https://www.classiczcars.com/forums/topic/59282-sold-triple-webers-5-speed-and-more/#findComment-540644 Share on other sites More sharing options...
January 24, 20187 yr comment_540645 How far north are you? I've got a red valve cover I'd trade! I'm in the panhandle once a month or so. Destin, Navarre beach. Gulf shores today. Construction, general contractor company. Link to comment https://www.classiczcars.com/forums/topic/59282-sold-triple-webers-5-speed-and-more/#findComment-540645 Share on other sites More sharing options...
January 24, 20187 yr Author comment_540662 Sent you a pm KindubZ. Siteunseen, let me think about that. Link to comment https://www.classiczcars.com/forums/topic/59282-sold-triple-webers-5-speed-and-more/#findComment-540662 Share on other sites More sharing options...
January 26, 20187 yr Author comment_540839 The valve covers and oil pan have been sold... Link to comment https://www.classiczcars.com/forums/topic/59282-sold-triple-webers-5-speed-and-more/#findComment-540839 Share on other sites More sharing options...
February 3, 20187 yr Author comment_541450 I would be willing to strip the powder coat off the intake manifold and heat shield and re- powder coat in practically any color you want if you purchase the Weber's (same price)...don't forget, free shipping. Now is a good time to get rid of some of that worthless Bitcoin Link to comment https://www.classiczcars.com/forums/topic/59282-sold-triple-webers-5-speed-and-more/#findComment-541450 Share on other sites More sharing options...
