I have seen photos of a lot of restorations where the replacement hard brake lines are not precise enough to fit inside the rubber frame mount bushings in the engine bay.
Has anyone bought brake lines & fuel lines from classictube.com?  Are the bends precise enough to fit in the existing frame mounts?
Thanks
https://www.classiczcars.com/forums/topic/59314-replacement-hard-brake-lines/
I found they where not exact, but fit well enough to work (I did have to bend in one spot).
Sent from my iPad using Classic Zcar Club mobile
Sent from my [device_name] using http://Classic Zcar Club mobile
Thanks for the post.
Most of the lines look correct but the brake line going under the tunnel looks like it stopped about 3 inches too soon before it made the bend to the rear.  Then the one running to the right front tire looks way off (which naturally is the line I need the most of course).  One line looks like it is touching your steering shaft?
The fuel line and the clutch lines look exact.
Guest
Reply to this topic...
