Hi,
Does anybody have a picture of how their wires are connected on their ignition coil and ballast resistor. I think mine might be connected wrong, the engine runs but the tachometer does not work. Any help would be appreciated.
Nick
Edited by footballnick17
There are only a couple of wires involved. The Green/White (GW) wire comes from Start position on the key, goes through the tachometer, and comes out Black/White (BW). That BW wire goes to the positive of the coil. There is another BW wire. It comes off the ignition switch and goes out to the ballast resistor (and also branches off to the fuse box). On the other side of the ballast resistor is a GW wire that connects to the GW wire described above.
Has the tach ever worked in the car since you owned it?
