Posted January 13, 20187 yr comment_539636 Hey guys, I'm brand new on here. I have a 75 280, and I'm having some issues. As most know, datsun is really weird about switching up their transistor ign modules throughout the years. Mine came with the E12-06, but I had a buddy who had a E12-27 that he'd sell me for cheap, so I grabbed it. However I've run into an issue. The 06 is a 7 pin (non cali), and the 27 is 5 pin, missing a brown and white wire. From what I've seen, the brown is a ground of sorts, but the white goes through the water temp relay to the water temp sensor (I'm assuming to advance/ retard turning when cold or at O.T.) My question is what should I do with the white wire? I may have to manually flip the relay somehow with a switch, but I might not have to. Any input will help! Link to comment https://www.classiczcars.com/forums/topic/59360-transistor-module-swap-pls-help/ Share on other sites More sharing options...
January 13, 20187 yr comment_539642 You have a 76 fed model with dual pick-up in the distributor. The second pick-up is activated by a temperature switch and relay. You can use the califorian model and go over the one pick-up. Link to comment https://www.classiczcars.com/forums/topic/59360-transistor-module-swap-pls-help/#findComment-539642 Share on other sites More sharing options...
January 13, 20187 yr Author comment_539644 I think I may have a single pickup dizzy. From what I saw. How big of an issue is That? Link to comment https://www.classiczcars.com/forums/topic/59360-transistor-module-swap-pls-help/#findComment-539644 Share on other sites More sharing options...
January 13, 20187 yr comment_539647 There's a whole thread about this somewhere very recent. Search around, or maybe Eurodat remembers. We both posted in it. Same question, almost exactly, slightly different form. Link to comment https://www.classiczcars.com/forums/topic/59360-transistor-module-swap-pls-help/#findComment-539647 Share on other sites More sharing options...
January 13, 20187 yr Author comment_539649 Alright I'll do some more digging. Thank you guys Link to comment https://www.classiczcars.com/forums/topic/59360-transistor-module-swap-pls-help/#findComment-539649 Share on other sites More sharing options...
January 13, 20187 yr comment_539650 You can read Marks thread on it. Its his restoration thread, but from page 68/69 hewent through a similar issue. Plenty of photos and diagrams I changed my module to a GM HEI a couple of years back and made a sjmple instruction on what I did to do the swap. TIU280Z1976_REV2 (1).pdf Edited January 13, 20187 yr by EuroDat Link to comment https://www.classiczcars.com/forums/topic/59360-transistor-module-swap-pls-help/#findComment-539650 Share on other sites More sharing options...
January 13, 20187 yr comment_539652 That was the thread. I forgot that it was part of a much bigger one. Never would have found it. Halo, are you just planning ahead with a spare, or having ignition problems? The GM HEI module swap is a better system, I think, with a new GM module, than using an old Nissan 7 pin module. Plus, the Nissan modules were "low energy" until 1978. And I think that after 1977 they were all 5 pin, so the -27 is probably have a low energy Nissan module. Use the GM module and appropriate coil, remove the ballast, and you'll be able to run a wider gap on your plugs and have a stronger spark. Link to comment https://www.classiczcars.com/forums/topic/59360-transistor-module-swap-pls-help/#findComment-539652 Share on other sites More sharing options...
January 13, 20187 yr comment_539655 My module just came in yesterday. I will be finishing the install soon. I have to work this weekend... Link to comment https://www.classiczcars.com/forums/topic/59360-transistor-module-swap-pls-help/#findComment-539655 Share on other sites More sharing options...
January 13, 20187 yr Author comment_539656 I will look into doing that. I'm just trying to get spark, haven't gotten spark since I got it. It's been such a nightmare. But mine is the black box, with a 5 pin connector rather than the normal one with wires and rings to connect it. Link to comment https://www.classiczcars.com/forums/topic/59360-transistor-module-swap-pls-help/#findComment-539656 Share on other sites More sharing options...
January 13, 20187 yr comment_539657 1 hour ago, Halo8u said: I think I may have a single pickup dizzy. From what I saw. How big of an issue is That? I think that EuroDat addresses the single versus dual pickups in his writeup. But, you don't need to swap distributors, you can use the just one of the two pickup coils that's in your current distributor. You'll have a spare pickup coil already installed if you do it that way. Link to comment https://www.classiczcars.com/forums/topic/59360-transistor-module-swap-pls-help/#findComment-539657 Share on other sites More sharing options...
January 13, 20187 yr comment_539658 3 minutes ago, Halo8u said: I will look into doing that. I'm just trying to get spark, haven't gotten spark since I got it. It's been such a nightmare. But mine is the black box, with a 5 pin connector rather than the normal one with wires and rings to connect it. There are some basic tests that you can do to figure out where the problem is. Have you confirmed power to the coil? Link to comment https://www.classiczcars.com/forums/topic/59360-transistor-module-swap-pls-help/#findComment-539658 Share on other sites More sharing options...
January 13, 20187 yr Author comment_539666 Yes, it shocked the hell out of me, found out the hard way Link to comment https://www.classiczcars.com/forums/topic/59360-transistor-module-swap-pls-help/#findComment-539666 Share on other sites More sharing options...
