Posted January 16, 20187 yr comment_539941 What is the best way to restore the carpet and padding in a 240z? Are there kits out there that work well, or should I just cut everything myself? Is there sound deadening material I should use? Link to comment https://www.classiczcars.com/forums/topic/59382-carpet-fix/ Share on other sites More sharing options...
January 17, 20187 yr comment_539954 There is no best way since Nissan does not sell carpet kit. You can purchase carpet kit at ebay that what I installed. Link to comment https://www.classiczcars.com/forums/topic/59382-carpet-fix/#findComment-539954 Share on other sites More sharing options...
January 17, 20187 yr comment_539956 There are 2 main approaches to the carpet. One is the factory pattern carpets.The other is more of a custom setup that usually covers the transmission tunnel and sometimes the rear strut towers. I am of course assuming "restore"means replacing. If not you could redye the carpet you have and respray vinyl to get good color. There was an older thread on the original supplier of the carpet kits @Zup If you do a custom kit they sometimes need massaging with heat to get them to fit properly  Link to comment https://www.classiczcars.com/forums/topic/59382-carpet-fix/#findComment-539956 Share on other sites More sharing options...
April 20, 20213 yr comment_620170 Alsooo... you can always call a carpet restore company 😄 Like, if I were you I'd rather call some professionals than try and fix something myself. Maybe it is cheaper, but not always practical. I agree that there are people who are talented at everything and can do better themselves. But let's be honest... not all of us are the same 🙂 When I burned a hole in my carpet, I called radiant carpet repairs, and they got it fixed and even brought it back to life with an update. And it didn't cost that much money. Sometimes, it is better to give some cash for a better job that will bring you satisfaction further 🙂 ______________________________________________________________________________ https://radiantcarpetrepairs.com.au/carpet-repairs-campbelltown/ Edited May 14, 20213 yr by Abywat Link to comment https://www.classiczcars.com/forums/topic/59382-carpet-fix/#findComment-620170 Share on other sites More sharing options...
April 20, 20213 yr comment_620174 On 1/16/2018 at 2:01 PM, trevorgrubb said:  What is the best way to restore the carpet and padding in a 240z? Are there kits out there that work well, or should I just cut everything myself? Is there sound deadening material I should use?  Cutting carpet to fit the Z, unless you do it for a living, probably won't give you the results you seek.  Preformed carpet sets are available for floor and rear deck at a reasonable price from several sources like: https://www.thezstore.com/page/TZS/CTGY/classic08g07 You can add sound deadening or heat insulating material under the carpet.  Again, many ways to go with costs that vary.  However, not a big expense for something functional that dresses up the Z interior. Dennis   Link to comment https://www.classiczcars.com/forums/topic/59382-carpet-fix/#findComment-620174 Share on other sites More sharing options...
April 20, 20213 yr comment_620176 1 hour ago, Abywat said: Alsooo... you can always call a carpet restore company 😄 Would they need my car or just the carpets? What about shipping? I have ACC 30 minutes from me so I'm a little prejudiced.  Link to comment https://www.classiczcars.com/forums/topic/59382-carpet-fix/#findComment-620176 Share on other sites More sharing options...
April 21, 20213 yr comment_620205 I was surprised when I found carpets for the ZX on Rockauto. They look pretty decent and have a couple of options to chose from. No idea on quality.I didn’t look for earlier Zs but would assume they do since they have them for the less loved ZX’s. Sent from my iPhone using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/59382-carpet-fix/#findComment-620205 Share on other sites More sharing options...
April 21, 20213 yr comment_620207 Can you get direct from ACC? That would be sweet. Just realized all Rocks is ACCSent from my iPhone using Tapatalk Link to comment https://www.classiczcars.com/forums/topic/59382-carpet-fix/#findComment-620207 Share on other sites More sharing options...
June 7, 20213 yr comment_622984 On 4/20/2021 at 7:39 PM, siteunseen said: Would they need my car or just the carpets? What about shipping? I have ACC 30 minutes from me so I'm a little prejudiced.  Tell me more, share a link. I vaguely recall seeing a thread on the topic but my summer work schedule has limited my Z homework time. thanks Link to comment https://www.classiczcars.com/forums/topic/59382-carpet-fix/#findComment-622984 Share on other sites More sharing options...
June 7, 20213 yr comment_622991 42 minutes ago, Trnelson said: Tell me more, share a link. I vaguely recall seeing a thread on the topic but my summer work schedule has limited my Z homework time. thanks https://www.accmats.com/ That's their website but you can buy way cheaper, about half their price buying from one of their vendors. rockauto.com is where I would buy but their carpets are all over Ebay too. Go to the website and get the kit number after you decide what you want then google that number + auto carpet and see what pops up. rockauto.com is quicker though. Lots of choices to consider. If I remember right the 70 thru 78 have loop originally but then they went to cut pile on the ZX. Link to comment https://www.classiczcars.com/forums/topic/59382-carpet-fix/#findComment-622991 Share on other sites More sharing options...
June 7, 20213 yr comment_622992 Acc direct 5 piece Rockauto.com 5 piece Link to comment https://www.classiczcars.com/forums/topic/59382-carpet-fix/#findComment-622992 Share on other sites More sharing options...
June 7, 20213 yr comment_622994 Well the Sweet'n Low has finally give me the Alzheimers. My original '72 240 has loop carpet but the original '77 280 is cut pile. Maybe 70 thru 73 is loop and the rest was cut? Sorry. I had to walk downstairs to look. Edited June 7, 20213 yr by siteunseen Link to comment https://www.classiczcars.com/forums/topic/59382-carpet-fix/#findComment-622994 Share on other sites More sharing options...
