Posted January 17, 20187 yr comment_540040 I'm wondering if anyone successfully re-cut key based on the key code from worn out original key? Someone said Dealer only store 10 years of data in the computer, the others say using VIN number lockthmith can re-cut new key. http://forums.nicoclub.com/key-cutting-by-vin-t301243.html My key is worn out and it easily falls off while running engine. I have spare ignition module, but I want to use the original key for door lock and ignition. There is a code on the key one letter and 4 digit number. I wonder whether I can re-cut based on the code somewhere. By the way, this key in the photo is from junkyard old 260z. You can't steal my car if someone successfully re-cut key for this :-) Link to comment https://www.classiczcars.com/forums/topic/59391-worn-out-key-re-cut/ Share on other sites More sharing options...
January 17, 20187 yr comment_540051 When I had a new key cut, I took the key code number from the glovebox door tag to a locksmith. Quick, easy, inexpensive. Dennis Link to comment https://www.classiczcars.com/forums/topic/59391-worn-out-key-re-cut/#findComment-540051 Share on other sites More sharing options...
January 17, 20187 yr comment_540057 On 1/17/2018 at 8:46 PM, psdenno said: When I had a new key cut, I took the key code number from the glovebox door tag to a locksmith. Quick, easy, inexpensive. Dennis Is that the only place the key code exists? I don't believe I have ever seen that tag on any Z I've ever owned Maybe on the lock cylinder? Edited January 17, 20187 yr by Patcon Link to comment https://www.classiczcars.com/forums/topic/59391-worn-out-key-re-cut/#findComment-540057 Share on other sites More sharing options...
January 18, 20187 yr comment_540058 I've read that it's on the passenger side door lock cylinder. Only the passenger side for some reason. I did like site did and took the number from the glove box door to a local locksmith. They didn't think twice, just looked up the cut in their books and made me some spares. Just went and looked at mine and it's a letter and four numbers. Like A1234. Link to comment https://www.classiczcars.com/forums/topic/59391-worn-out-key-re-cut/#findComment-540058 Share on other sites More sharing options...
January 18, 20187 yr comment_540063 Mine was "M 5150", from glove box. Very fitting, code for involuntary psych hold. Link to comment https://www.classiczcars.com/forums/topic/59391-worn-out-key-re-cut/#findComment-540063 Share on other sites More sharing options...
January 18, 20187 yr comment_540064 On 1/18/2018 at 1:13 AM, siteunseen said: Very fitting, code for involuntary psych hold. ...and you would know that because...? Link to comment https://www.classiczcars.com/forums/topic/59391-worn-out-key-re-cut/#findComment-540064 Share on other sites More sharing options...
January 18, 20187 yr comment_540066 Britney Spears. Link to comment https://www.classiczcars.com/forums/topic/59391-worn-out-key-re-cut/#findComment-540066 Share on other sites More sharing options...
January 18, 20187 yr comment_540074 On 1/18/2018 at 1:13 AM, siteunseen said: Mine was "M 5150", from glove box. Very fitting, code for involuntary psych hold. It also makes a good personalized license plate. Dennis Link to comment https://www.classiczcars.com/forums/topic/59391-worn-out-key-re-cut/#findComment-540074 Share on other sites More sharing options...
January 18, 20187 yr comment_540076 Van Hagar. Link to comment https://www.classiczcars.com/forums/topic/59391-worn-out-key-re-cut/#findComment-540076 Share on other sites More sharing options...
January 18, 20187 yr comment_540081 On 1/18/2018 at 2:30 AM, Captain Obvious said: Van Hagar. I forgot about that album, thank goodness. Sammy Hagar sang "why can't this be love?" Because you SUCK! David Lee is Van Halen. Those brothers were just in his band. Link to comment https://www.classiczcars.com/forums/topic/59391-worn-out-key-re-cut/#findComment-540081 Share on other sites More sharing options...
January 18, 20187 yr comment_540084 Haha!! So no Sammy love, huh? I can listen to all of it, but I agree... The best stuff is the early DLR stuff. Link to comment https://www.classiczcars.com/forums/topic/59391-worn-out-key-re-cut/#findComment-540084 Share on other sites More sharing options...
January 18, 20187 yr comment_540086 The only good Hagar is Montrose Hagar. Link to comment https://www.classiczcars.com/forums/topic/59391-worn-out-key-re-cut/#findComment-540086 Share on other sites More sharing options...
