February 5, 20187 yr comment_541574 Wow. Nice. I wish I could find NOS door cards. Darn 75-76 unicorn panels. Link to comment https://www.classiczcars.com/forums/topic/59436-240zrubberparts-project-car/?&page=2#findComment-541574 Share on other sites More sharing options...
February 5, 20187 yr comment_541576 3 hours ago, DatsunZGuy said: Replated AM radio housing? And I thought I was OCD Outstanding restoration and fantastic attention to detail. You have no idea!!! Steve has plated stuff that will probably never see the light of day again. Reproduced tags for the wiring harnesses. Truly a museum class restoration! Link to comment https://www.classiczcars.com/forums/topic/59436-240zrubberparts-project-car/?&page=2#findComment-541576 Share on other sites More sharing options...
February 5, 20187 yr comment_541605 Isn’t the plastic a vapor barrier to Prevent moisture inside the doors from reaching the door panels? I always thought if moisture got in the doors, I would want it to escape any way it could. And if the sheet metal could dry at the expense of the door panels, so be it. Am I looking at it wrong? Link to comment https://www.classiczcars.com/forums/topic/59436-240zrubberparts-project-car/?&page=2#findComment-541605 Share on other sites More sharing options...
February 5, 20187 yr comment_541621 Guess you could say "if the factory put it in , we should" IMO Most of the Z's after 45 years don't have it in there anyway.....dealers choice. Link to comment https://www.classiczcars.com/forums/topic/59436-240zrubberparts-project-car/?&page=2#findComment-541621 Share on other sites More sharing options...
February 6, 20187 yr comment_541639 9 hours ago, 87mj said: Isn’t the plastic a vapor barrier to Prevent moisture inside the doors from reaching the door panels? I always thought if moisture got in the doors, I would want it to escape any way it could. And if the sheet metal could dry at the expense of the door panels, so be it. Am I looking at it wrong? The door will dry even with plastic in place. The door isn't air tight even with the window up. When the window is down there is even more ventilation. If you expose the door panels to moisture they will warp, mold and generally do bad things. I have multiple sets that exhibit this type of damage. Link to comment https://www.classiczcars.com/forums/topic/59436-240zrubberparts-project-car/?&page=2#findComment-541639 Share on other sites More sharing options...
February 17, 20187 yr Author comment_542526 It is all in the details. new rollers and inserts.... No wonder it is going on a 5+ year restoration.... Link to comment https://www.classiczcars.com/forums/topic/59436-240zrubberparts-project-car/?&page=2#findComment-542526 Share on other sites More sharing options...
March 9, 20187 yr Author comment_544080 I have been working on the seat. Replated the hardware, sandblasted frame, painted with 2k ceramic black, new webbing and new stainless steel carriage bolts. I have new foam and new seat covers. I have about 10 hrs in just this seat. Link to comment https://www.classiczcars.com/forums/topic/59436-240zrubberparts-project-car/?&page=2#findComment-544080 Share on other sites More sharing options...
March 9, 20187 yr comment_544081 Did Norm plate it for you? Link to comment https://www.classiczcars.com/forums/topic/59436-240zrubberparts-project-car/?&page=2#findComment-544081 Share on other sites More sharing options...
March 9, 20187 yr Author comment_544082 1 hour ago, Patcon said: Did Norm plate it for you? No, I'm back plating again. You need to come see the car when you are back over my way.... Link to comment https://www.classiczcars.com/forums/topic/59436-240zrubberparts-project-car/?&page=2#findComment-544082 Share on other sites More sharing options...
March 9, 20187 yr comment_544083 1 minute ago, nix240z said: No, I'm back plating again. You need to come see the car when you are back over my way.... Yes I do! I could pick your brain on plating too, now that I have done some. Link to comment https://www.classiczcars.com/forums/topic/59436-240zrubberparts-project-car/?&page=2#findComment-544083 Share on other sites More sharing options...
March 9, 20187 yr Author comment_544085 1 hour ago, Patcon said: Yes I do! I could pick your brain on plating too, now that I have done some. Ok let me know. i will plate some stuff, so that you can see what works for me... Link to comment https://www.classiczcars.com/forums/topic/59436-240zrubberparts-project-car/?&page=2#findComment-544085 Share on other sites More sharing options...
March 9, 20187 yr Author comment_544086 few other things I have been working on.. Some NOS parts..Side markers, Turn signal harness ,Datsun Sill plates and early style scuff plates with vinyl not painted Link to comment https://www.classiczcars.com/forums/topic/59436-240zrubberparts-project-car/?&page=2#findComment-544086 Share on other sites More sharing options...
