240zrubberparts project car
nix240z
23 hours ago, nix240z said:
I have been working on the seat.
Replated the hardware, sandblasted frame, painted with 2k ceramic black, new webbing and new stainless steel carriage bolts.
I have new foam and new seat covers.
I have about 10 hrs in just this seat.
Hi Steve , I am amazed all of your fantastic work. Can I buy the seat bottom webbing from somewhere? Yours is just like the original, cream white rubber strips associated with olive green cloth pieces.
Just wonderful!
Kats
Just wonderful!
Kats
Kats it is called Pirelli Rubber Upholstery Webbing 2"..... and yes it is just like the original
I'm curious who's hard brake lines did you use?  Did you buy new or did you replate your old ones?
Also, same question for your door seals?  Did you go with aftermarket or did you have NOS set aside?  If you went with aftermarket, do you need to slam your doors?
original hardlines and I used vintage rubber door seals, I did purchase these about 4 years ago so not sure if still the same.. I do not have to slam the doors .
On 3/8/2018 at 10:54 PM, nix240z said:
Rebuilt and replated the original 70-71 Tokico 7/8" master cylinder.
A rebuild kit (pistons, seals, etc) for the early brake m/c seems to be NLA.  Where did you find yours?   Or did you just re-use your original internals?
It was a total rebuild kit I picked up from Ebay at some point....
  • 10 months later...
  • Who's Online   0 Members, 0 Anonymous, 610 Guests (See full list)
