Zed Head Posted January 31, 2018 Share #25 Posted January 31, 2018 Just gabbing... The car looks very solid. The dinged up floor reinforcements, aka rails, look amazingly rust free. Even the little weep holes look like they might still have original paint on the edges. 1 Link to comment Share on other sites More sharing options...
gwri8 Posted January 31, 2018 Share #26 Posted January 31, 2018 Three things optically here that trick the eye. Wide angle lens, camera off center by about 1/2 step, and camera tilted. Here it is not tilted. It helps a little. Link to comment Share on other sites More sharing options...
siteunseen Posted January 31, 2018 Share #27 Posted January 31, 2018 (edited) 2 hours ago, Zed Head said: Probably normal. I know that the engine is tilted. Just never noticed how far off the oil pan was from center. Look at the middle of the crossmember. I tried to find the car on the California CL's but couldn't. Wonder if he bought it yet. When I first got started adjusting my valves I went with them straight up, mistakenly. After i figured out how much tilt there is I Sharpied center lines on the cam towers to point the lobes at. Much quieter valve train now. 8^) I think the oil drain is off center Zed, but without climbing under there??? Heres a Zx pan I have upstairs. Its on center with the ridge between the 2nd & 3rd lines like the photo of the OP car. Edited January 31, 2018 by siteunseen Link to comment Share on other sites More sharing options...
sweatybetty Posted February 1, 2018 Share #28 Posted February 1, 2018 look at the casting line on the bottom of the trans. It lines up with the center of the cross-member. Link to comment Share on other sites More sharing options...
Zed Head Posted February 1, 2018 Share #29 Posted February 1, 2018 Nothing says that the casting line has to be centered! The drain plug isn't. One of the other pictures shows though that the bottom of the pan is level with the car which is right. So, just an odd angle seems to be why the first one looked weird to me. So the pan has uneven side lengths so it rides level and the drain plug is centered in the pan but not to the car. Just haven't been under my car in so long I forgot what it all looked like. Link to comment Share on other sites More sharing options...
DatsunZGuy Posted February 1, 2018 Share #30 Posted February 1, 2018 I live just a few miles away from Vazquez Rocks, where the photos were taken. If the owner lives nearby, I haven't seen it on the road. Looks to be solid example and nice for a weekend driver. Link to comment Share on other sites More sharing options...
AlbatrossCafe Posted February 1, 2018 Share #31 Posted February 1, 2018 Buy it and sell me the bumpers for $300. Then it will only cost you a much more affordable $16.2k 1 Link to comment Share on other sites More sharing options...
MinimumSafe Posted February 1, 2018 Author Share #32 Posted February 1, 2018 I won’t be changing the interior at all, just some cosmetics. Appreciate the input guys! Link to comment Share on other sites More sharing options...
BDJeff Posted February 1, 2018 Share #33 Posted February 1, 2018 I just bought one almost identical to this one for $15,150 so yes, it appears to be a good deal. But I agree with some of the other guys, if you're going to modd it up, you're paying a lot for stuff you're going to remove/change anyway. Link to comment Share on other sites More sharing options...
