JDMjunkies.ch Posted February 4, 2018 Share #13 Posted February 4, 2018 (edited) sorry, wrong thread Edited February 4, 2018 by JDMjunkies.ch Link to comment https://www.classiczcars.com/topic/59477-wtb-close-ratio-5-sp-trans-and-engine-belly-pan/?page=2#findComment-541535 Share on other sites More sharing options...
Diseazd Posted February 4, 2018 Share #14 Posted February 4, 2018 (edited) Just curious Tom and Mike. What is involved in buying the Quaife R180 LSD insert that Whitehead sells and installing in our existing R180 diff? Is that a job for the do it yourselvers or is it a job for a diff shop? Edited February 4, 2018 by Diseazd Link to comment https://www.classiczcars.com/topic/59477-wtb-close-ratio-5-sp-trans-and-engine-belly-pan/?page=2#findComment-541537 Share on other sites More sharing options...
Tj320z Posted February 4, 2018 Author Share #15 Posted February 4, 2018 Depends on your DIY skills. Takes some gaging to ensure bearing preload, pinion to ring position (gears messing correctly) and gear backlash. You can probably find info online that will detail the general steps but, I suspect best left to an appropriate shop. Tom Link to comment https://www.classiczcars.com/topic/59477-wtb-close-ratio-5-sp-trans-and-engine-belly-pan/?page=2#findComment-541540 Share on other sites More sharing options...
Diseazd Posted February 4, 2018 Share #16 Posted February 4, 2018 Thanks Tom.....you bet I’ll take it to a pro then. Is the Quaife unit stronger than the stock? Would that eliminate the need to go R200? How much horsepower is too much for an R180 Quaife LSD ? Link to comment https://www.classiczcars.com/topic/59477-wtb-close-ratio-5-sp-trans-and-engine-belly-pan/?page=2#findComment-541541 Share on other sites More sharing options...
7tooZ Posted February 4, 2018 Share #17 Posted February 4, 2018 Most require professional installation for any type of warranty. Some offer life time warranty that is transferable if professionally installed. Not much is worse than a clucking diff. Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/topic/59477-wtb-close-ratio-5-sp-trans-and-engine-belly-pan/?page=2#findComment-541542 Share on other sites More sharing options...
Tj320z Posted February 4, 2018 Author Share #18 Posted February 4, 2018 From what I've heard the R180 is reasonably robust. If you're just hot rodding the original L series should be fine. If you're looking to do a high HP turbo swap you should move to an R200 or other. Link to comment https://www.classiczcars.com/topic/59477-wtb-close-ratio-5-sp-trans-and-engine-belly-pan/?page=2#findComment-541544 Share on other sites More sharing options...
Diseazd Posted February 4, 2018 Share #19 Posted February 4, 2018 (edited) None are stock.....all are modified L28’s.....HP varies from 190 at the flywheel to 250 (Stroker). Only thrash em in a straight quarter mile run.....Quaife R180 ok? I don’t really want to do an R200 swap if not necessary. Edited February 4, 2018 by Diseazd Link to comment https://www.classiczcars.com/topic/59477-wtb-close-ratio-5-sp-trans-and-engine-belly-pan/?page=2#findComment-541545 Share on other sites More sharing options...
7tooZ Posted February 4, 2018 Share #20 Posted February 4, 2018 Ps I did a similar install to a R200 last year. Labor, seals and bearings cost $850 w/o ring & pinions. Had excellent results. Sent from my iPhone using Classic Zcar Club mobile Link to comment https://www.classiczcars.com/topic/59477-wtb-close-ratio-5-sp-trans-and-engine-belly-pan/?page=2#findComment-541546 Share on other sites More sharing options...
Mike W Posted February 4, 2018 Share #21 Posted February 4, 2018 Guy, I consider my son and I pretty good mechanics, but installing an LSD and getting all of the preloads and backlash correct is probably out of our element. Not to mention that I probably don't have all of the right tools either. I would definitely have it installed and setup by a pro. And as @7tooZmentions will preserve your warranty as well. Also, and I am far from an expert on this, but there are also different types of LSD's depending on the kind of driving that you are going to do. The Quaife is based on a gear design and is a 1 way LSD meaning that it locks under acceleration and free wheels during braking. This was recommended for basic spirited street driving which is why I went that way. The OS Giken is a clutch based design and can be configured as either 1 way, 1.5 way, or 2 way where the 1.5 and 2 configuration provides either moderate or full lock under braking which is useful for tracking or drifting. On the 180 vs 200 I decided that seeing I was going to change anyway and do have more HP than a stock setup, the 200 made sense and it wasn't really any more money except for the fact that I had to change the mustache bar as well. It in end it was probably a bit of an overkill for my application but I should never have to worry about it again. If you've got more questions on the different types of diffs, etc I'd recommend talking to Mike at Whitehead. He was extremely helpful and informative when I was in the decision process and definitely knows the S30 platform. Hope that helps. Mike. 1 Link to comment https://www.classiczcars.com/topic/59477-wtb-close-ratio-5-sp-trans-and-engine-belly-pan/?page=2#findComment-541547 Share on other sites More sharing options...
Tj320z Posted February 18, 2018 Author Share #22 Posted February 18, 2018 Bump...Found CLSD. Still looking for Close Ratio 5 Speed and also an OEM belly pan. Link to comment https://www.classiczcars.com/topic/59477-wtb-close-ratio-5-sp-trans-and-engine-belly-pan/?page=2#findComment-542642 Share on other sites More sharing options...
black gold man Posted February 18, 2018 Share #23 Posted February 18, 2018 I do have one it is in a 83 i bought a few years ago with front damage. Since 1986 it sat in a body shop only 22000 miles 1500 shipped to you in ny. Motor is there too. I know they go fro 3-4 hundred but 22000 miles i wanted to keep but i need money and space in garage. bill Link to comment https://www.classiczcars.com/topic/59477-wtb-close-ratio-5-sp-trans-and-engine-belly-pan/?page=2#findComment-542650 Share on other sites More sharing options...
Tj320z Posted February 18, 2018 Author Share #24 Posted February 18, 2018 Thanks Bill... PM'd you. Link to comment https://www.classiczcars.com/topic/59477-wtb-close-ratio-5-sp-trans-and-engine-belly-pan/?page=2#findComment-542657 Share on other sites More sharing options...
