November 6, 20195 yr comment_587050 hi mark , today I bought the blue label 3-in-one oil it is different from the red label one I was using . still had some stumble of line after I richen the back carb but it was better so I went ahead and changed the damping oil to the blue label 3-in-one which is 20wt. the motor idles better and most of the stumble is gone probably about 95% gone. it still could be a tad lean but I do not think by much. I like the fact that I have no fumes in the cabin at all and it idles great. I have to remember this is a carb car and not fuel injection. I will check the plugs again when the motor cools down and see where I am at . thanks again for the tip on the Nissan 20wt damping oil. kully Link to comment https://www.classiczcars.com/forums/topic/59521-bending-float-tab-direction-3-screw-su/?&page=6#findComment-587050 Share on other sites More sharing options...
November 6, 20195 yr comment_587055 That's what I use too. No problems with mine, they have a good response from a dead stop. Blue 3 in 1 from Lowes. Link to comment https://www.classiczcars.com/forums/topic/59521-bending-float-tab-direction-3-screw-su/?&page=6#findComment-587055 Share on other sites More sharing options...
November 6, 20195 yr comment_587072 I will have to check lowes thanks ,I could only find a 3 oz can from ace hardware!! Link to comment https://www.classiczcars.com/forums/topic/59521-bending-float-tab-direction-3-screw-su/?&page=6#findComment-587072 Share on other sites More sharing options...
November 6, 20195 yr comment_587073 It's in the tool section at my local Lowes. About $3 if i remember right. That small amount will outlast me. Link to comment https://www.classiczcars.com/forums/topic/59521-bending-float-tab-direction-3-screw-su/?&page=6#findComment-587073 Share on other sites More sharing options...
November 7, 20195 yr comment_587085 yes I saw it on the lowes web site. It looks like only made and sold in the 3oz cans but cheaper from where I bought it from. I know 1 can is plenty but I like to have a spare .it seems as I get older I like to have a little stock . it is good for my compressor motor also thanks siteunseen Link to comment https://www.classiczcars.com/forums/topic/59521-bending-float-tab-direction-3-screw-su/?&page=6#findComment-587085 Share on other sites More sharing options...
November 7, 20195 yr comment_587106 On 11/6/2019 at 3:06 AM, Mark Maras said: If your plugs look good and the only problem is a little stumble off the line, you may want to run heavier wt. oil in the dampeners. Nissan recommended 20 wt. I always used ATF with good results. I would also like faster response when i launch from 1st gear at stop lights. Car lacks some response when accelerating from stops. Link to comment https://www.classiczcars.com/forums/topic/59521-bending-float-tab-direction-3-screw-su/?&page=6#findComment-587106 Share on other sites More sharing options...
November 7, 20195 yr comment_587107 On 11/7/2019 at 4:21 AM, jalexquijano said: I would also like faster response when i launch from 1st gear at stop lights. Car lacks some response when accelerating from stops. What wt. oil are you using? I've heard about others using heavier weight oils than 20wt. Tales of 30wt. all the up to 80-90 gear oil. Not that I recommend 80-90wt. but it would be fun to try 30wt and 40wt. to see if there's a noticeable difference. If you do try it be sure to let us know your impressions. Link to comment https://www.classiczcars.com/forums/topic/59521-bending-float-tab-direction-3-screw-su/?&page=6#findComment-587107 Share on other sites More sharing options...
November 7, 20195 yr comment_587110 ATF!!! Link to comment https://www.classiczcars.com/forums/topic/59521-bending-float-tab-direction-3-screw-su/?&page=6#findComment-587110 Share on other sites More sharing options...
November 7, 20195 yr comment_587127 On 11/7/2019 at 5:17 AM, jalexquijano said: ATF!!! Dump the ATF out of the dampeners and try some 20wt. Let us know of any noticeable changes. Link to comment https://www.classiczcars.com/forums/topic/59521-bending-float-tab-direction-3-screw-su/?&page=6#findComment-587127 Share on other sites More sharing options...
November 7, 20195 yr comment_587128 What about 3 in 1 blue bottle? I have a couple.of those bottles. Link to comment https://www.classiczcars.com/forums/topic/59521-bending-float-tab-direction-3-screw-su/?&page=6#findComment-587128 Share on other sites More sharing options...
November 7, 20195 yr comment_587129 On 11/6/2019 at 3:02 AM, Mark Maras said: Yup, looks iffy to me. I'm not a big fan of rubber fuel lines in contact with the body. In the pic above it looks like the hose is too long. Cut it short enough to eliminate the body contact. Last time i removed that hose it was a complete disaster and spill of gas all over. Do i really need to cut it and tighten again? Link to comment https://www.classiczcars.com/forums/topic/59521-bending-float-tab-direction-3-screw-su/?&page=6#findComment-587129 Share on other sites More sharing options...
November 7, 20195 yr comment_587130 On 11/7/2019 at 2:27 PM, jalexquijano said: Last time i removed that hose it was a complete disaster and spill of gas all over. Do i really need to cut it and tighten again? Work quick! You can use a rag or some paper towels to wick the oil out of the dampers with out having to disassemble the carbs Link to comment https://www.classiczcars.com/forums/topic/59521-bending-float-tab-direction-3-screw-su/?&page=6#findComment-587130 Share on other sites More sharing options...
