February 15, 20187 yr comment_542378 What's an Xtl? I have a 78 clock in my 76 and the old non-working 76 on the shelf in the garage. I'll have to watch your videos. Link to comment https://www.classiczcars.com/forums/topic/59541-every-z-owners-fantasya-working-clock/?&page=2#findComment-542378 Share on other sites More sharing options...
February 15, 20187 yr comment_542379 Xtl short hand for Crystal Link to comment https://www.classiczcars.com/forums/topic/59541-every-z-owners-fantasya-working-clock/?&page=2#findComment-542379 Share on other sites More sharing options...
February 15, 20187 yr comment_542380 I guess I got lucky with my 71 clock. When I purchased my car in 1984 the clock did not work and I never worried about it. A few years ago when I had the dash out, I took the back off the clock and noticed one of the wires had come off the solder. Soldered it back on and it started working. It must have had a bad solder job from factory and probably only work for a little while. Link to comment https://www.classiczcars.com/forums/topic/59541-every-z-owners-fantasya-working-clock/?&page=2#findComment-542380 Share on other sites More sharing options...
February 15, 20187 yr comment_542381 I guess the real question is the freq of the xtl, could use a freq counter and get a ball park figure see if its near a standard clock freq. a schematic would give all the answers. Link to comment https://www.classiczcars.com/forums/topic/59541-every-z-owners-fantasya-working-clock/?&page=2#findComment-542381 Share on other sites More sharing options...
February 15, 20187 yr comment_542382 So, capacitor, broken wire, or bad crystal (Xtl) are the things to consider. Curious - do you save your videos in a high-res format? My ISP is supposed to be 4O Mbps but I get the spinning circle on some youtube videos, like yours. I think it's just crappy CenturyLink servers but who knows. It's funny how bad the internet still is even though the "speeds" are supposedly orders of magnitude faster than 54 KB. Which was the fastest phone modem speed for quite a while. Just checking. Low res might get them to play better. Link to comment https://www.classiczcars.com/forums/topic/59541-every-z-owners-fantasya-working-clock/?&page=2#findComment-542382 Share on other sites More sharing options...
February 15, 20187 yr comment_542385 cheap o camera pretty sure its low res. I am not good with modern tech stuff. and yes internet speed is a joke I pay for 60mps or what ever I get 7mps per the speed test. Edited February 15, 20187 yr by Dave WM Link to comment https://www.classiczcars.com/forums/topic/59541-every-z-owners-fantasya-working-clock/?&page=2#findComment-542385 Share on other sites More sharing options...
February 15, 20187 yr Author comment_542386 On 2/15/2018 at 4:30 AM, Dave WM said: cheap o camera pretty sure its low res. I am not good with modern tech stuff. and yes internet speed is a joke I pay for 60mps or what ever I get 7mps per the speed test. Do you think this crystal is still available?Thanks for all of your knowledge and support.Phil Smith Link to comment https://www.classiczcars.com/forums/topic/59541-every-z-owners-fantasya-working-clock/?&page=2#findComment-542386 Share on other sites More sharing options...
February 15, 20187 yr comment_542387 Really don't know much about its make, but I would guess its not something hard to find. A freq counter will tell. Could also try a scope and freq gen to see where it want to resonate. Interesting puzzle. I don't have much exp with Xtls beyond what I used in the color tv repairs so can not say if that 4194.5 is a freq or a part number or what. A HAM may know. Edited February 15, 20187 yr by Dave WM Link to comment https://www.classiczcars.com/forums/topic/59541-every-z-owners-fantasya-working-clock/?&page=2#findComment-542387 Share on other sites More sharing options...
February 15, 20187 yr comment_542388 MHz 4.194304 Real-time clocks, divides to 1 Hz signal (222×1 Hz). Also found in the original Game Boy hmmm maybe Link to comment https://www.classiczcars.com/forums/topic/59541-every-z-owners-fantasya-working-clock/?&page=2#findComment-542388 Share on other sites More sharing options...
February 15, 20187 yr comment_542397 4194.5 KHz... or 4.1945 Mhz i think.. is the frequency of that cristal... I've got me a old 240z clock with new 1,5 volt clock inside an old housing.. looks old but has new mechanics/electrics inside.. I'm still looking for a 1979 280zx WORKING clock... Link to comment https://www.classiczcars.com/forums/topic/59541-every-z-owners-fantasya-working-clock/?&page=2#findComment-542397 Share on other sites More sharing options...
April 5, 20186 yr comment_546716 Quartz mechanism Ouch! your really going the wrong direction when working on the quartz mechanism. The electronics with this clock is rock solid and good to about 50 pts per mil. I have never seen a bad Xtl or cap on these mechanisms. The problem is nearly always mechanical and usually missing teeth on the two nylon gears . There are other mechanical problems , but to lengthy for this post. Std 280 mechansm If your going to work on the ckt board you need to: 1- make sure the coils are good. If the flywheel slightly moves it doesn't mean the coil isn't shorted or it will work if you replace all the parts. There are 2 coils , each has a difference resistance, and there are 2 versions of the ckt bd! 2-You need to replace ALL 3 caps (with exact values)and the tran. As mentioned in "DAVE WM" video the coil wires are very small, about 38 gauge , and a bear to replace. You can do everything right and still cook the coil in the process. Difficulty for replacing these parts is VERY HIGH, Unless you have done a lot of micro soldering and have the right tools I wouldn't attempt to replace these parts. Just my 2C Zclocks Link to comment https://www.classiczcars.com/forums/topic/59541-every-z-owners-fantasya-working-clock/?&page=2#findComment-546716 Share on other sites More sharing options...
April 5, 20186 yr comment_546719 FWIW - I've got one of zclocks quartz converted units installed, purchased from MSA a few years ago. Great product and highly recommended. Link to comment https://www.classiczcars.com/forums/topic/59541-every-z-owners-fantasya-working-clock/?&page=2#findComment-546719 Share on other sites More sharing options...
