Runs rich, wont rev past 2-3k
240DL?
this is what I did, best to use analog meter, I setup a simple voltage divider using some 9v batteries. Hopes its just a ground wire, but if you are still getting no where after checking that, you could get all 3  out on the bench and do a test like this.
For rev limiting, I have witnessed three causes:
1. The EFI system has a false Idle signal from the TVS due to a short.  The ECU thinks that the foot is off the pedal and will not flow gas above ~2800rpm
2. The ignition system has a fault. I'm my case, a points distributor was the cause.  The power died under load at high rpms as if there was a fuel cut-off.
3. Weak fuel pressure.  Weak fuel pressure is not an issue with no load (revving in neutral) but under load on the road, there will not be sufficient fuel to power the car beyond a certain rpm X load point.
And to check that put your fuel gauge on a hose and zip tie it to the driver's wiper arm.  Go for a drive and watch it fall or hopefully stay the same.
1 hour ago, 240DL? said:
 Is it possible to check simply with resistance if it is functioning correctly?
I see a lot of "correct"s and "good"s and questions that should be clear if you were in the right place of the FSM or Guide for testing.  The only numbers you've shown are a couple of RPM values. The AFM resistance values are in the FSM.  Easy to measure, even from the ECU connector.  The way the FSM is set up is that if the continuity/no continuity super-quick tests don't find a problem then you go to the more time-consuming tests of actually getting resistance numbers.  This thread is starting just like about 20 others over the last few years.  No offense, everybody tries to find the quick "bad part" solution.  Post as many numbers as you can measure, and include the AFM and ECU part numbers.
Two kind of hidden ways to run really rich are a hole in the FPR diaphragm or a bad ECU.  A bad ignition module can also send too many pulses to the ECU while failing.  Usually that will also show up on the tachometer with funky needle movement.  And, to make things possibly worse, if it ran bad when you got it then the PO probably messed with things to try to fix it.  A common mistake is to adjust the AFM vane position.  You might have to go through and reset almost everything.
  • Who's Online   0 Members, 1 Anonymous, 853 Guests (See full list)
